185 on 7.5?
Old Jan 29, 2012 | 08:41 PM
Minicoopr50's Avatar
Minicoopr50
185 on 7.5?
so 7.5 inches is about 190 MM.
I ordered 185 55's for these.
The tire is a 185 55 16 Hakook going on konig roller 16 x 7.5.
This should fit right?
Old Jan 29, 2012 | 08:55 PM
bluefox280's Avatar
bluefox280
Is this for a 2nd-Gen application?
If so, the OEM tires are 195/55 on a 16" wheel.
So your 185 will have a smaller contact patch and shorter sidewall.
Yes, they will fit.
- Erik
Old Jan 29, 2012 | 08:59 PM
Minicoopr50
Yes, they will fit.
- Erik
These arent stock wheels.
Im putting konig 16 x 7.5's on my r50.
But will a 185 55 R16 fit on a 16 x 7.5 in wheel.?
Old Jan 29, 2012 | 09:11 PM
bluefox280's Avatar
bluefox280
Yeah, I read that on the first response.
Yep.
For reference the R50 OEM 16" tire is a 195/55.
So again, your 185/55 will have a smaller contact patch and smaller sidewall than the OEM combination.
- Erik
Old Jan 29, 2012 | 09:14 PM
Minicoopr50
Yep.
- Erik
Thanks for the help Erik!
Old Jan 30, 2012 | 04:25 AM
yetti96's Avatar
yetti96
Why would you want a smaller tire? The tire will possibly have a stretched look to it with minimal rubber protection to the wheel.
Old Jan 30, 2012 | 09:08 AM
hsautocrosser's Avatar
hsautocrosser
The maximum approved wheel width for a 185/55-16 tire is 6.5".
Old Jan 30, 2012 | 04:22 PM
Jim Michaels's Avatar
Jim Michaels
To elaborate on what posts #6 and #7 are suggesting, the 185/55/16 tires are too narrow for the 16X7.5 wheels. They can be mounted on the wheels (one meaning of "fit"), but their performance would be far from optimal. So they won't "fit" in that sense.
185/55/16s have a rim range from 5.0 to 6.5", and are molded for a 6.0" rim.
205/50/16s have a rim range from 5.5 to 7.5", and are molded for a 6.5" rim.
225/45/16s have a rim range from 6.0 to 8.0", and are molded for a 7.0" rim. Some are molded for a 7.5" rim, but there are very few tire choices in this size anyway.
Thus, at least a 205 width would be advised, but a 225 width would work even better.
There may be complications, however. The pictures of your wheels mounted without tires on another thread seem to show some poke already. If you mount wide tires and also install lowering springs (I read that thread too), you may have clearance problems.
My last gasp thought is that wide wheels and tires will add a few more pounds of unsprung rotating mass at each corner, thus affecting acceleration and braking; especially on a MC.
ki7hy
Suspension
Mar 13, 2016 08:45 PM
Marcurell
Tires, Wheels, & Brakes
Sep 26, 2015 04:53 PM
Mini'mon
Aug 16, 2015 04:15 PM
BelowRadar
Feb 2, 2005 07:48 AM
MiniMac
Jul 31, 2004 06:18 PM
