R56 Fog lights for Justa?
Still waiting on my Cooper and I'm wondering if they come pre~wired for fog lights. I didn't order it with them and I'm interested in installing the LED ones myself.
Fog lights Justa
See link below on LED lights which were just installed by a Clubman owner. He is sending me the directions on how to remove the bumper to install these lights. I will send you two more emails on the subject since I do not know how to send more than one link at a time
http://www.outmotoring.com/product.p...cat=339&page=1
Fog lights Justa
All my references are for the DRLs/fog lights that fit in the bumper. My Mini does not have the fog lights it only has the DRLs ( justa Mini) I want to replace the factory with these LED ones, which will give me the Fog light option. I think I can use the factory DRL wires to run the DRL part of the LEDs but will have to add a switch and wire to the battery the Fog lights.
Are you looking for "functioning" fog lights or just the "look?" The reason I ask is as the prior poster states, the 2012 come with what I think are daylight running lights down there stock. I was going to order the fog lights mainly because I don't like the look of empty holes that many cars have if you don't, but I ended finding the exact MCa I was looking for (sans cloth sports seats) on the lot and was surprised to see lights down there. I don't remember those DRL's showing up when I did my build on the Mini site...
Living on the OR coast and a "car gal" if I am hearing you right, you probably want the real thing. Just wanted to throw that out there. Here on the SoCal coast I'm happy with the DRL's so far.
Cricketine -
You're right, the configurator is misleading, or at least it was when we were ordering. If you don't specify fog lights, the configurator shows empty fog light openings. Truth is, though, all MINIs come with lights in the fog light holes, it's just a matter of how many: 1 DRL per hole, or a DRL and a Fog. This is for the pre-refresh R56s, in particular, but it may be the same for 2011+ as well. (Sounds like the same goes for the 2011+ based on the above posts!)
Did you order it that way or get a freebie? I can't remember if you got any packages.
) I think perhaps when the dealership ordered it, they ticked rear fog by mistake.
Someone posted a thread on this, but it was for a pre-LCI. Supposedly the wiring is there and there is even a bulb in the socket. To make it work, I believe you have to buy the switch, switch cover and get the footwell module programmed at the dealer.
Yup, foggy on the coast more often than not! Functioning fog lights would come in handy.
Cricketine -
Thanks!
from the link
"In 2011 MINI redesigned the front and rear bumpers and have a new design for the front and rear lower grill and these parts will NOT fit. Please look in our exterior lighting category for the 2011 facelift rear fog light kit. "
Also they are there to allow oncoming traffic to distinguish the center-line of the car if one of the headlights are out.
DRL is different. On MINI it is a programmed function you can enable and disable via the stalk on the tach display.
For MINI the DLR's turn on the headlights to full power AND all the other lights on as well.... tail, license & markers. On other makes of cars, DRL's turn on just the headlights at partial brightness.
FWIW you can install oem fog lights without removing the bumper. If you remove the fog light from its mounting bracket you can insert both pieces into the cavity below the headlight and reassemble them once they're in place. On the right side you can insert the light reflector thru the access hole in the fender liner. The left side is a little trickier because the windshield washer bottle is in the way. On that side you have to partially remove the fender liner and washer bottle to squeeze the reflector into the cavity. It took me about 15min (after I removed the headlights and grill) to install the right light and about 45min for the left. An offset torx screwdriver will be very handy for mounting the lights behind the bumper.
Sep 28, 2021 01:16 PM
Aug 21, 2015 12:58 PM
Aug 21, 2015 12:50 PM
Aug 19, 2015 12:51 PM
