R50/53 Metric Belt Size?
Old Jan 16, 2012 | 11:27 AM
niquemarshall's Avatar
niquemarshall
Metric Belt Size?
Hey im trying to figure out the size of the belt with just a supercharger pulley added. I have no idea what size/brand this pulley is, just that its a lightweight pulley. I know i can just use a jcw belt, but i dont want to wait like 5 days for it to mail in. I would rather go to oreillys or so and get a metric belt from there. Any suggestions?
Old Jan 16, 2012 | 07:21 PM
abjb's Avatar
abjb
Take a look at this (posts 30 and 31), it’s in the “Modifications How-To” sub forum.
Looks like NAPA (Part # 060539) or NAPA 25-060535.
I found a few belts/#’s while searching for belts, plugs fluids, etc that I needed to change this summer/fall.
You should probably read the whole thing.
https://www.northamericanmotoring.co...-how-to-2.html
post a picture of the pulley, someone will recognize it
ab
Old Jan 16, 2012 | 08:13 PM
ZippyNH's Avatar
ZippyNH
No need to buy a metric belt....
When you say lightweight pulley...is it on the sc or is it the crank damper pulley?!
The size of the pulley...eiither one, will determine the beltsize....
60535 length belt is good for a 15% or 17% reduction....if cank damper was changed...then you need to know if it is stock size, or +2%....(most "lightweight" pullies are these....the sc pullies are so small, snd tiny diameter, weight does not matter...the thermal expansion contraction rate being the same as the sc shaft is much more important...so most sc pullies are stainless or regular steel.
But belts are cheap....install one....look at the tensioner...see if it is about right....should be a few pics around of what a proper lengrh belt appears to look like....
Old Jan 16, 2012 | 08:40 PM
niquemarshall
I have the lightweight pulley on the SC.. No crank pulley here, lol dot wanna wear out my engine..
Went to NAPA with part numbers only to find out those "numbers" didn't exist according to their computer.. I just want to order a standard belt size so I don't have to fork out $30 for a new one
Old Jan 16, 2012 | 08:41 PM
niquemarshall
And idk how the belt tensioner is supposed to look...
Old Jan 17, 2012 | 07:08 AM
ZippyNH's Avatar
ZippyNH
6 rib 535 length...any counter guy can get you that belt, any auto store...multiple brands. Think the stock may be 1388 mm length...so you could guestimate the amount you want shorter...most any auto store should have a chart listing metric vs us length equivelents...
elverado
Jan 18, 2022 02:51 AM
got_mini?
Oct 18, 2015 08:39 AM
lotiman
Sep 16, 2015 06:47 PM
hong
Sep 13, 2015 06:41 PM
Emnotek
Sep 11, 2015 04:16 PM
