Site Feedback Open forum for discussion of this site. Post your kudos or criticism so that we can continually improve service to the new MINI community.
Trouble getting to this site
Old Feb 23, 2004 | 12:41 PM
Fidge's Avatar
Fidge
I have been trying to bring up NAM for two days and I kept getting some sort of "test" page. Finally I was able to back in from the oil change page that I saved in my favorites. Anyone else have this trouble?
Old Feb 23, 2004 | 01:03 PM
NRX13's Avatar
NRX13
I was having troubles because one of my bookmarks was still linked to minicooperonline.com , is that the problem you're having?
Old Feb 23, 2004 | 01:09 PM
AppleCello's Avatar
AppleCello
No i had trouble a few days ago too. It was a DNS thing, i think because i was being directed to a Second Hand babies clothiong page, i believe it was... no clue but it works now.
Patrick
Old Feb 23, 2004 | 01:13 PM
Fidge's Avatar
Fidge
I guess that could be the problem. In my favorites I have the link listed as North American Motoring :: MINI COOPER, news, forums Is this causing a problem? I tried again and keep getting the same Test Page. Once again I was able to get on the site thru the R-Speed oil change page which I saved.
Old Feb 23, 2004 | 01:24 PM
no_affiliation's Avatar
no_affiliation
Check the properties of your link it will give you address it's trying to go to.
Old Feb 23, 2004 | 01:32 PM
dave's Avatar
dave
pug poo picker-upper
moving to site feedback
The minicooperonline mirror has been turned off. Other than that, I'm not sure.
Mark?
Old Feb 23, 2004 | 01:40 PM
Fidge's Avatar
Fidge
>>Mark?
I have tried just typing in the address: Northamericanmotoring.com, and still get this page with the title: Test Page Apache Web Sever. I guess I'm the only one with this problem.
Old Feb 23, 2004 | 01:51 PM
Mark's Avatar
Mark
North American Motoring :: Founder
I have turned off the redirect to North American Motoring if you happen to use a url with minicooperonline.com in it. That said if you do use minicooperonline.com you should receive a message indicating that the domain is being decommissioned and that you should visit North American Motoring.
As for your particular experience do you have access to a command line in Windows where you can run the following command?
DOS> ping https://www.northamericanmotoring.com
It should come back with something similar to the following:
Reply from 66.216.97.179: bytes=32 time=65ms TTL=236
If you don't see the above mentioned IP address please let me know what you do see. Feel free to email me directly at the address below. Thanks!
Mark
Old Feb 23, 2004 | 02:16 PM
Fidge's Avatar
Fidge
Here is the problem:Test Page
This page is used to test the proper operation of the Apache Web server after it has been installed. If you can read this page, it means that the Apache Web server installed at this site is working properly.
If you are the administrator of this website:
You may now add content to this directory, and replace this page. Note that until you do so, people visiting your website will see this page, and not your content.
If you have upgraded from Red Hat Linux 6.2 and earlier, then you are seeing this page because the default DocumentRoot set in /etc/httpd/conf/httpd.conf has changed. Any subdirectories which existed under /home/httpd should now be moved to /var/www. Alternatively, the contents of /var/www can be moved to /home/httpd, and the configuration file can be updated accordingly.
If you are a member of the general public:
The fact that you are seeing this page indicates that the website you just visited is either experiencing problems, or is undergoing routine maintenance.
If you would like to let the administrators of this website know that you've seen this page instead of the page you expected, you should send them e-mail. In general, mail sent to the name "webmaster" and directed to the website's domain should reach the appropriate person.
For example, if you experienced problems while visiting http://www.example.com, you should send e-mail to "webmaster@example.com".
The Apache documentation has been included with this distribution.
For documentation and information on Red Hat Linux, please visit the Red Hat, Inc. website. The manual for Red Hat Linux is available here.
You are free to use the image below on an Apache-powered Web server. Thanks for using Apache!
You are free to use the image below on a Red Hat Linux-powered Web server. Thanks for using Red Hat Linux!
Old Feb 23, 2004 | 02:18 PM
Fidge's Avatar
Fidge
Anyone know what this means?
Old Feb 23, 2004 | 02:35 PM
Mark's Avatar
Mark
This is a standard page that comes up when you are configuring an Apache web server. In the case of our server this was displayed for a few hours early Sunday morning. All that it means is that the server was up and operating at the time. You should not receive this at this point when accessing the site. If you are there may be a reason why...the page is being cached by your browser in some way. If you are using Internet Explorer try the following to see if it resolves the issue when going to https://www.northamericanmotoring.com:
1) In IE, go to Tools/Internet Options
2) Click on Settings under Temporary Files
3) Select "Every visit to the page"
4) Click OK
5) Click OK
6) Enter the url https://www.northamericanmotoring.com
Let me know if this changes any of the behavior you are seeing.
Mark
Old Feb 23, 2004 | 03:09 PM
Fidge's Avatar
Fidge
>>4) Click OK
>>5) Click OK
>>Mark
Well, this is weird, I don't have a problem getting to the site using Internet Explorer. But I have not been using IE, I guess I will have to now unless there is another way to correct the problem? Thanks for your help Mark.
Old Feb 23, 2004 | 03:14 PM
Mark's Avatar
Mark
Are you using the AOL browser by chance?
Mark
Old Feb 23, 2004 | 07:35 PM
Fidge's Avatar
Fidge
>>Mark
Yes, I guess so. Like I said, I'm not a computer guy but I usually get onto AOL and then put NAM in the url. Now I can only use IE? :???:
Old Feb 23, 2004 | 07:48 PM
Mark's Avatar
Mark
Let me contact AOL tomorrow and ask them why this may be happening. There is nothing that I'm aware of on our site that should prevent you accessing it through AOL's browser. I find it strange that only in the last two weeks have I started getting reports about similar problems with the AOL browser.
Thanks!
Mark
Old Feb 24, 2004 | 08:29 PM
Fidge's Avatar
Fidge
Mark,
Just wondering if you may have gotten anywhere with AOL.
Thanks,
Old Feb 24, 2004 | 08:40 PM
Mark's Avatar
Mark
Not as of yet. A couple of issues came up today that consumed most of my time. I have it on my list of things to investigate tomorrow.
Mark
Old Feb 24, 2004 | 09:01 PM
binkysmini's Avatar
binkysmini
Mark,
I just read this thread, so I opened my AOL and typed the site name (without www.) in their browser bar. It took me to the site just fine. Took about 30 seconds, but got me there.
Cheers,
John L
Old Feb 28, 2004 | 04:39 PM
Moorlockx's Avatar
Moorlockx
My problem was AOL was redirecting me to MINIUSA.com. It lasted for a couple days but now seems to be operating as it should.
Old Feb 29, 2004 | 03:01 PM
Mark's Avatar
Mark
Are others still having AOL-related problems? From Moorlockx's experience it almost sounds like there was some form of DNS or link caching going on. Perhaps the AOL browser has DNS or caching information that is only updated after several days. Given that I stop the MCO redirect about the time that this problem surfaced perhaps it took some time for the changes to propogate through the AOL browser.
All theory aside let me know if other AOL browser users are still having problems. To date I've been unable to find a contact at AOL that could address this issue.
Mark
Old Mar 10, 2004 | 08:54 AM
JFEINSTEIN's Avatar
JFEINSTEIN
Mark, I'm being redirected to MINIUSA.com by clicking on galleries in the NAM Pulse. In addition, we I tried to log directly into NAM this morning, it also redirected me into MINIUSA.com. I never had any problems before and I've had AOL all along. Any ideas. I am able to access the PULSE directly, which is how you are hopefully getting this message. Jon
Old Mar 10, 2004 | 09:07 AM
Mark's Avatar
Mark
JFEINSTEIN,
I'll email you to see if we can get this resolved. Thanks!
Mark
chowpott
Oct 19, 2015 08:37 AM
navybsn
Oct 4, 2015 03:27 PM
