merry christmas to me! and a quick question...
Old Dec 25, 2011 | 12:30 PM
bksmith76's Avatar
bksmith76
I'm a very happy man right now, got surprised with a full set of Motegi MR125s
So i tossed one on the cooper to see what it looked like - keep in mind that i'll be mounting a 235/40 r17 on it for autocross. Do ya'll think i'll need a spacer? Looks a bit tight on the strut back there, about 1/2" or a touch less.
Old Dec 25, 2011 | 01:04 PM
Eddie07S's Avatar
Eddie07S
Nice wheels.
That is a larger tire size than what I have seen on Minis. What is the wheel rim width and offset (should be stamped on the inside of the wheel somewhere)? I have seen 225s fit, but on a lowered car they rubbed on the wheel wells (40 mm offset wheels). So this may be more of a question of fitting between the strut/springs and the wheel well.
Do a search, I know this subject has come up before. And look in the SCCA Solo 2 and ProSolo Forum (you might want to post this question there). For autocross the allowed tire size and changes to the offset will depend on the class you expect to be in. You might want to check the governing body (SCCA?) rules before you invest too much.
At any rate - Nice Wheels and Merry Christmas!
Old Dec 25, 2011 | 02:16 PM
dannyhavok's Avatar
dannyhavok
No idea, but nice wheels! They were a serious contender for me. Ended up getting used Feathers instead, but I like the look of the Motegi a lot.
Old Dec 25, 2011 | 10:20 PM
bksmith76's Avatar
bksmith76
Originally Posted by Eddie07S
Nice wheels.
I'll be running in STX which allows the size wheels and tires i'm planing on. I know others have run 235s on minis before but you need to get the offset just right... once i get some rubber mounted on the rims i'll be sure to report back my findings.
and Merry Christmas right back at ya and everyone else in NAM land!
Old Jan 3, 2012 | 08:30 PM
bksmith76's Avatar
bksmith76
Thought i would post an update - a local tire shop hooked me up with a used 235/45 17 so i could do some test fits and see what everything looked like. I'm happy to report they clear the stock struts with about a 1/4" to spare and little to no rubbing from what i can tell rolling around - this was a loaner tire and I only had one so i couldn't drive it...
see pictures below, but i have no doubt that a 235/40 will fit with coil overs and gives a very nice stance with the rims and wheels pushed way out to almost exactly flush with the fenders.
difference between my 215/45s and the 235/45s
top down view
http://www.flickr.com/photos/67363027@N08/6632503041/
clearance at the spring perch
http://www.flickr.com/photos/67363027@N08/6632503715/
dirty tire, clean rim, stock looking wheel gap (soon to change!)
http://www.flickr.com/photos/67363027@N08/6632504811/
look at that stance! (the jack is just stuck under there, the weight is all on the wheel)
http://www.flickr.com/photos/67363027@N08/6632505281/
stock on the other side with 215/45s
http://www.flickr.com/photos/67363027@N08/6632506213/
side shot
http://www.flickr.com/photos/67363027@N08/6632506641/
a tight fit with the 235/45 - that is a flat head screwdriver that just barely fits between the tire and the wheel well liner - a 235/40 will help a ton here.
http://www.flickr.com/photos/67363027@N08/6632508077/
rear stance
http://www.flickr.com/photos/67363027@N08/6632509493/
rear side shot
http://www.flickr.com/photos/67363027@N08/6632508531/
can't wait to get the full set mounted up with some real rubber.
gnhovis
Dec 14, 2015 05:31 PM
navybsn
Oct 4, 2015 03:27 PM
dutchhome
Sep 30, 2015 07:17 AM
simron
Sep 23, 2015 10:02 PM
12R58JCW
R58 :: Coupé Talk (2012+)
Sep 22, 2015 11:31 AM
