18x8 on 215/40/18 +45 offset - PICS
Old Dec 25, 2011 | 08:03 AM
texasmontego's Avatar
texasmontego
New wheels and tires. After a lot of research I decided on the following setup and couldn't be happier.
Wheels: 18x8 +45 offset Tenzo Type M
Tires: Continental Extreme Contact 215/40/18
Suspension: Stock MCS
The wheels sit perfect in the wheel wells. No rubbing. In fact, I could probably use a small spacer and bring them out a hair (maybe 3-5mm).
Big thanks to AccessTD for his advise & bringing his car over for me to look at before purchasing the wheels/tires.
Next is the H&R Springs. The Mini Mud Flaps are on order.
Old Dec 25, 2011 | 08:21 AM
peterpan101's Avatar
peterpan101
normally don't like black w/ red stripe but on that color combo it looks awesome!
Old Dec 25, 2011 | 08:22 PM
texasmontego
Same with me, but when they were put on i really like the look. I think it looks better in person than it does in pictures. Can't wait to install the springs now.
Old Jan 12, 2012 | 06:26 PM
Socially Distorted's Avatar
Socially Distorted
With your setup, how much clearance do you have between the tire/wheel and the inner suspension? I'm curious if anyone has fit an 18x8.5 and what offset was required. I think it's a little too big.
Old Jan 12, 2012 | 07:16 PM
Braminator's Avatar
Braminator
Looks good. What did the rims weigh?
Old Jan 13, 2012 | 07:16 AM
texasmontego
Socially Distorted - There isn't much clearance b/w the suspension and the wheel. the +45 offset with a 8" wide wheel looks to be the max that would fit. You would definitely need a much lower offset to get an 8.5" wheel. I think if I went with a 225 tire, the tire would rub. So far, so rubbing at full lock. I think I'm going to go with a small spacer to bring them out a little. Don't get me wrong, I'm happy with it, but I think a couple of mm pushed out would make it that much better without going beyond the wheel well arches.
Braminator - I weighed them before I installed them and if I remember correctly 22-23lbs comes to mind. The wheel/tire setup was about 8 lbs heavier per wheel than my stock 17's. I notice a slight difference when shifting (I have an auto) from 2nd to 3rd (takes a little longer), but I'm real detailed oriented. I doubt any normal person would notice. Biggest thing I noticed was the improved ride quality and reduced road noise going to the Non-Runflats. I was skeptical at first, but really came down to $$$. The NonRF were ~$550, the runflats were over $1000. I'm really happy with my decision.
Old Jan 13, 2012 | 05:01 PM
Socially Distorted
Yeah, I think a 3mm spacer would be about perfect for the rear end to sit flush. Looks good.
My thoughts with a 8 1/2" wide wheel is to mount up the 2010 Subaru STI Limited 18" wheel and run an 18-20mm adapter. The setup would end up with a 35-37mm offset. I did a Photochop of this wheel on a Mini R53 and it looks really good! IMO. But it may. It work since it would push the outer lip out about 30mm from stock.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
Chibi2
May 19, 2016 03:46 PM
OldElvis
Oct 5, 2015 07:31 PM
NYXF56JCW
Oct 3, 2015 04:27 AM
MINI Stupor
Oct 1, 2015 11:36 AM
