Suspension Camber plates
Old Dec 21, 2011 | 10:40 PM
Cawtou's Avatar
Cawtou
Camber plates
So I was doing researching and there are several brand camber plates available like Eibach, Vorshlag, and IE. Anyone recommend one over the other?
Old Dec 22, 2011 | 03:08 AM
cmt52663's Avatar
cmt52663
I use Google, with the "site:northamericanmotoring.com" expression added to my other search words so that results will come only from NAM.
Using that trick got me this, which looks like it contains some threads worth reviewing.
Kind regards,
Charlie
Old Dec 22, 2011 | 07:32 PM
countryboyshane's Avatar
countryboyshane
I researched this quite a bit last year before settling on Vorshlag. The attention to detail, quality, and adjustment range are hard to beat. The downside is that you'll have to wait a while to get them and they cost a bit more than the rest.
Old Dec 23, 2011 | 07:34 AM
Mindspin311's Avatar
Mindspin311
What are you trying to accomplish? You potentially could get away with simply the fixed plates from IE if you just want to add some camber to the front.
If you're going for full adjustability, then the Vorshlag's are probably your best bet.
Old Dec 26, 2011 | 08:14 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Vorshlags are by far the best for the R56.
Old Dec 30, 2011 | 02:25 PM
alex123's Avatar
alex123
same here - could not have said it better myself. you could see top notch quality once you get them out the box.
Old Dec 30, 2011 | 08:55 PM
sooper_cooper's Avatar
sooper_cooper
I use the Vorshlags as well. Solid as a rock and work great, probably the best option for the R56.
Old Jan 3, 2012 | 04:19 PM
modernbeat's Avatar
modernbeat
While they do cost more than most, they still represent a good value.
And Vorshlag usually ships same day the order comes in.
Old Jan 4, 2012 | 07:55 PM
countryboyshane
If they have all the parts in stock.
I placed my order at a time when they were waiting for parts to be laser cut and it took longer than expect. Yes, very much worth the wait but I think people should know that these plates are put together by a mom & pop operation, not on a super dooper production line.
Old Jan 5, 2012 | 04:55 PM
modernbeat's Avatar
modernbeat
Yeah, those were the days...
Now Vorshlag has five and a half people, and a big shop where a full time fabricator does a lot of the fab work in house and a full time mechanic does installs.
Old Jan 6, 2012 | 03:18 PM
bluefox280's Avatar
bluefox280
Has anyone used SPC Performance (#67630) front camber camber plates?
- Erik
Old Jan 9, 2012 | 08:46 AM
Cawtou's Avatar
Cawtou
it seems vorshlags are the way to go. now just gotta save up for them
Old May 29, 2012 | 02:34 PM
bahawton's Avatar
bahawton
Just installed the SPC plates & they increased NVH quite a bit on rough roads. The plastic interior panels rattle more than they used to. They also raise the front of the car 3/8".
got_mini?
Oct 7, 2015 02:12 PM
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
