Suspension Koni Sport Shocks vs Vmaxx Coil Overs?
Old Dec 16, 2011 | 05:01 AM
IQRaceworks's Avatar
IQRaceworks
I'm thinking upgrading the stock worn out shocks on my 03' MCS with 90,000 miles on it.
I was looking at WMW, and they have the Vmaxx coil over shocks for $649 a full set, or the Koni Sport Shocks for $724. What would be the better route to go for a daily driver? I'm sure the Konis are a better shock, but are the Vmaxx's worth it for the extra adjustable in ride height? Or are the Koni's with stock springs going to be better what I want (better ride).
Any info would be great! Also, are there any other shocks I should look at that aren't super expensive....these are pricey enough!!
Old Dec 16, 2011 | 05:07 AM
THE ITCH's Avatar
THE ITCH
If you do not plan on lowering the Koni FSD's would probably give you a slightly better ride than the Sports.
Steve
Old Dec 16, 2011 | 05:48 AM
daflake's Avatar
daflake
If I were choosing between those two, I would go with Koni. The VMaxx are an entry level coil over and you really do get what you pay for.
As the other poster mentioned, the FSD are also a great choice (can't lower them). I just had these installed and they are awesome. The regular ride is much improved and when you get aggressive they tend to keep the car from rolling in the turns. Very nice...
Old Dec 16, 2011 | 06:10 AM
blue2turbo's Avatar
blue2turbo
I'm willing to bet the VMAXX coilovers are not going to ride anywhere near as nice as Koni Sports or FSD's. Also, Koni offers a lifetime warranty on their shocks which is a HUGE selling point for me.
Personally, I already lowered my mini on Swift Springs and I will be upgrading to Koni Sports hopefully next spring. If I hadn't lowered, FSD's would be the way I would have gone.
Old Dec 16, 2011 | 07:30 AM
IQRaceworks
Can someone explain why you can't use the shorter "lowered" springs with the FSD's but you can with the sports? They look the same physically...do they have less travel??
As far as the internal valving goes...anyone know what the difference is with the sports vs the FSD's?
Thanks!!
Old Dec 16, 2011 | 08:18 AM
daflake's Avatar
daflake
http://www.koni.com/58.html
By shortening the travel of the strut you most likely are putting more pressure on the internal valves which can cause them to fail. So, Koni doesn't recommend using lowering springs.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Da_jesus
Aug 25, 2015 04:20 PM
sabjcw
Aug 14, 2015 07:40 AM
Emnotek
Aug 13, 2015 05:47 PM
ki7hy
Aug 12, 2015 07:07 PM
