R56 oil pressure warning?
Old Dec 16, 2011 | 04:34 AM
thinkinmini's Avatar
thinkinmini
So while turning into a parking lot last night the message came up that read something like "low oil pressure-shut off engine immediately to avoid damage" so i shut it off, and the dipstick read fine. drove it back home, roughly a 15 min trip w/o any more issues. what could this be?
Old Dec 16, 2011 | 04:38 AM
schatzy62's Avatar
schatzy62
Well if you checked the oil right after shutting the engine down it will not read right. you need to let the engine sit for a while, like 15 minutes or so then check the oil. And if it is truly low a hard sharp corner can cause this to happen.
Old Dec 17, 2011 | 07:25 AM
LostinTX's Avatar
LostinTX
Low oil pressure doesn't mean low on oil itself. Get that checked out. It may be a harmless sensor not reading correctly or could be a pump going out on you.
You did say in a parking lot, so probably not revving the engine. Low pressure can be a sign of someting devious.
Cheers
Old Dec 17, 2011 | 03:42 PM
CLoso17's Avatar
CLoso17
it means very low oil
Old Dec 17, 2011 | 04:42 PM
masternut's Avatar
masternut
Very low oil pressure
Old Dec 17, 2011 | 04:57 PM
fergy016's Avatar
fergy016
It could very well be a few things causing the cel,
1. sensor failing
2. low oil
3. failing oil pump
4. a fluke
Old Dec 18, 2011 | 12:51 PM
thinkinmini
yah i checked it 15mins after shutting it down back at my house, it was very low. do minis burn oil? it's barely been 5k miles since my last full synthetic change (1 free change from the dealer i got it from), did they just not add enough oil? I remember checking that day and saw it read fine but maybe i misread it.
Old Dec 18, 2011 | 02:12 PM
Eddie07S's Avatar
Eddie07S
Just to alarm you a little more...with the S model there is a vacuum pump and there are posts about the vacuum going out after low oil pressure and when they go, the whole engine goes. I would:
- get the engine checked out.
- do a search on NAM for info about the vacuum pump
- highly consider replacing the vaccum pump
- from now on, check the oil level immediately after it is changed (by anyone). The car takes 4.5 qts and most places will only put in 4 qts. It needs the full amount with the turbo.
Old Dec 18, 2011 | 04:07 PM
gregsmini's Avatar
gregsmini
Yes, Eddie is right, there have been some catastrophic results from low oil.
I check my oil every week, use about one quart per 6k miles.
Everyone's oil consumption varies, I'm not sure if your consumption is excessive or not. I would definitely keep an eye on it.
Kimolaoha
Jul 5, 2023 01:04 PM
TREX
Nov 2, 2019 07:31 PM
Lschneider
Aug 21, 2015 02:21 AM
JamJam43087
Aug 16, 2015 02:02 PM
