Possible to install a pre-06 Rim to a after-06 MINI?
Old Dec 15, 2011 | 03:00 AM
greenrocket's Avatar
greenrocket
Hey Guys
Any help would be appreciated.
Is there any way you can install a rim with the pre-06 small lug size to a after-06 Mini with the larger lug size?
Are there any conversion studs etc out there i can get?
Thanks.
Old Dec 15, 2011 | 03:05 AM
greenrocket
found it...
http://www.waymotorworks.com/m14-to-...rsion-kit.html
Old Dec 15, 2011 | 06:29 AM
JPMM's Avatar
JPMM
15" R53 holies fit on a R56 with normal brakes with R56 lug bolts no problem
Old Dec 15, 2011 | 05:42 PM
ScottRiqui's Avatar
ScottRiqui
All of the OEM MINI rims since the beginning have had the same centerbore diameter, bolt spacing, and most importantly, the same diameter bolt holes (about 16 mm). As a result, the "pre 14 mm" wheels will bolt up to a car with 14 mm lug bolts with no problem. The only potential problem is that I believe some of the earlier MINI wheels won't accept the TPMS sensors required for the later "direct" TPMS system.
Old Dec 16, 2011 | 04:30 AM
Tall Mini's Avatar
Tall Mini
Yup... that is what I have on the 08 Clubbie. Tight fit but they work great.
Old Dec 16, 2011 | 06:00 AM
Tio Barry's Avatar
Tio Barry
Ya my 2010 has steel wheels and snows from '02 with r56 lug bolts no problem, also no TPMS.
Old Jan 6, 2012 | 06:24 PM
Albiecrazy's Avatar
Albiecrazy
I currently have an aftermarket wheel (tuner style lugs) on my Gen 2 (’08). I am selling them and a Gen 1 owner (’04) is interested - wants to send me $$$ now! Buyer beware and all that doesn’t work for me - don’t want to screw him... Will he be alright?
Old Jan 6, 2012 | 06:26 PM
ScottRiqui's Avatar
ScottRiqui
Since you have larger lug bolts than he does, I can't imagine there being a problem.
EDIT - Unless, of course, they're really big wheels (like 18s), with an offset that brings the rim/tire really close to the wheel well or suspension components. In that case, the lower ride height of his '04 could conceivably cause interference issues. But as far as center bore diameter, bolt spacing and bolt hole diameter, he should be golden.
Old Jan 7, 2012 | 05:54 AM
Albiecrazy's Avatar
Albiecrazy
Thanks, Scott. He’s never questioned it so I assumed he knew they would work. So even though MINI has gone to a larger lug for the Gen 2’s, the threads are the same?
Old Jan 7, 2012 | 07:03 AM
bluefox280's Avatar
bluefox280
No, the R50/R53 are M12 x 1.5.
The R55/R56/R57/R58 are M14 x 1.25.
On July 12, 2006 the size of wheel bolts was changed from M12x1.5 to M14x1.25.
There exists a misconception that this change in wheel bolt size precludes fitting early OEM wheels on later model cars.
This is simply not true as all OEM wheels have holes large enough for either size wheel bolt.
- Erik
Old Jan 11, 2012 | 06:04 PM
Albiecrazy's Avatar
Albiecrazy
Thanks for clearing things up, bluefox. I’m working on getting the buyer a new set of lugs that will work - his OEM lugs won’t work since these wheels bolt up with a tuner style lug.
Old Jan 22, 2012 | 01:17 PM
youreaspeedemon's Avatar
youreaspeedemon
other way around?
I'm looking and can't find yet whether or not the rims can go the other way around.
Will 2010 Clubman S Wheels (205/45R17 5 spokes) fit onto a 2002 Cooper S that has regular brakes (non JCW) I have the opportunity to purchase a set for a good deal but want to know prior to committing and driving out there.
Thanks in advance.
Glen
Old Jan 22, 2012 | 01:46 PM
kazlot's Avatar
kazlot
Possible to install a 2010 rim to a 2002 MINI?
Yes they will work.
The only difference will be the TPMS sending units inside the wheel.
They are not required for your car and if left in the wheel will not cause any problems.
Hope this helps...
Old Jan 22, 2012 | 01:54 PM
youreaspeedemon
cool thanks for the quick reply
that said about the tpms, will the indirect system that is on the 2002 still be able to detect a rotational difference and set the light.
reason I'm asking is because it has the runflats on the rims and if one of the tires gets a puncture the sidewall won't collapse and it might not set the light and i will be driving on a flat until it deteriorates and potentially causes a wreck.
Thanks again
Old Jan 22, 2012 | 04:46 PM
ScottRiqui's Avatar
ScottRiqui
Yes, the indirect TPMS will detect a rotational difference when one tire starts going flat, even with run flats.
Old Jan 22, 2012 | 05:12 PM
Porthos's Avatar
Porthos
Is it a problem take 15in 5 Star off a R56 fit on and R52? Just checking for a friend.
Old Jan 22, 2012 | 06:20 PM
ScottRiqui's Avatar
ScottRiqui
Can't think of a reason why it would be a problem.
Old Jan 22, 2012 | 08:39 PM
Porthos's Avatar
Porthos
Just checking thanx
Old Jan 24, 2012 | 01:36 PM
youreaspeedemon
Yeah, thanks for the reply I guess my brain was on autopilot when I asked the question. For some reason it slipped my mind that my car's ('02) OE tires were runflats... duh!
I guess I was just too excited about getting a full set of Clubman 17's (R110 Pace-spoke ET48) with tires that have about 80% tread left for $250....
He just needed to get rid of them before his wife figured out he replaced his wheel set....
He made my day and they fit perfectly on an 02 MCS
I will say this though, having nearly slick 50 series 16's and changing them over to nearly full tread 45 series 17's there is definitely some truth to the comments stating that you will accelerate a little slower with larger wheels (bigger circumference), that plus the extra weight at each corner I guess makes it noticable, not huge but definitely not as quick off the line.
Thanks for your answers, I picked up a great set of wheels and tires for dirt cheap.
Alkaidovich
Jan 30, 2021 01:35 AM
Mini'mon
Aug 26, 2015 01:02 PM
1chaos52
Aug 24, 2015 01:28 PM
nomar116
Aug 9, 2015 09:42 AM
