Alignment issue
Old Dec 12, 2011 | 06:25 PM
Singha's Avatar
Singha
Alignment issue
anyone else experience issue with the car going one way or another? In my case to the right?
Old Dec 12, 2011 | 06:45 PM
chrunck's Avatar
chrunck
How sharply to the right? Most roads slope to the right for water drainage, so a slight drift to the right is to be expected.
Old Dec 14, 2011 | 04:28 PM
MINItitan's Avatar
MINItitan
Had my car aligned first week I had it. Still pulls slightly right.... MA says they all do it. Kind of drives me batty.....
Old Jan 3, 2012 | 05:57 AM
alexsharp's Avatar
alexsharp
Just noticed my 2012 S pulls noticably to the right...might be the road slope but I am having it checked to be sure.
Old Jan 3, 2012 | 07:21 AM
mjgood's Avatar
mjgood
When I had my '05 MCS, I found that a couple psi difference in the tire pressure would cause a pull, It was even more noticeable when accelerating.
For a slight pull, try increasing the pressure on the side its pulling to, one tire may be a few psi different than the other, but the car will go straight..
Of course set it using a level road.....
Haven't had any trouble with my CM.
Old Mar 20, 2012 | 11:44 PM
Dain's Avatar
Dain
Had my 2012 Countryman S for about a month now. It was pulling to the right and at times at freeway speeds, 65-75, there would be a very slight wobble, it seemed like I had to quickly adjust my steering back and forth to stay in the center of my lane. It was very frustrating to be dealing with this on a new car. So I took it in to the dealer, they re-balanced the tires, checked the alignment. Now the pull to the right is much less noticeable, but it's still kinda there. The wobble has also not happened as often, but again like the pulling issue, it still kinda happens. I'll see if it gets any worse before taking it back to the dealer again.
Old Mar 21, 2012 | 07:58 AM
DR61's Avatar
DR61
If alignment and wheel balance are good, it could be a defect with one tire that doesn't affect balance. Perhaps suggest that the dealer rotate the tires front to back and see if it changes the problem.
Old Aug 5, 2012 | 06:03 PM
busyguy8's Avatar
busyguy8
Sorry to bring up an old thread, but mine pulls to the left. Will be taking it in for an alignment.
Old Aug 5, 2012 | 07:57 PM
shark715's Avatar
shark715
That's what old threads are for We are approaching 3k miles on ours, and there's no pull at all, although I'm feeling a very slight vibration at highway speeds that was not there when it was brand new. Almost not even worth mentioning, and I assume it's nothing worse than a tire slightly out of balance.
rikaro
Aug 7, 2021 02:33 PM
maestro39
Oct 27, 2015 02:38 PM
Drumsound
Sep 4, 2015 04:53 AM
L3Mix
Aug 26, 2015 07:00 PM
ASRman
Aug 13, 2015 09:33 AM
