Suspension tire cupping lowered hr cup kit
Old Dec 2, 2011 | 10:50 PM
turboevo2's Avatar
turboevo2
Hi Guys I lowered my My clubman s with hr cupkit and i use Falken tire 452 front and rear and had it aligned as well. But now I have tire cupping on the rear tires.
I read online that if only the rear tires has cupping it will just need alignment for the rear.
Just wondering if anyone who has lowered their car experienced the same and what advice can you guys give? I will change the rear tires but need advice on what to do to prevent cupping.
Thanks!
Old Dec 3, 2011 | 11:27 AM
mini4tide's Avatar
mini4tide
Add air to your tires. They are underinflated is my guess.
Old Dec 5, 2011 | 09:44 AM
bluefox280's Avatar
bluefox280
Correct; what's you're toe reading on the rear after your alignment?
- Erik
Old Dec 5, 2011 | 12:17 PM
Jim Michaels's Avatar
Jim Michaels
Cupping is often due to worn shocks.
Under-inflation produces excessive (but smooth) wear at both inside and outside edges.
Old Dec 7, 2011 | 05:42 PM
e30r56's Avatar
e30r56
When is the last time you rotated your tires? Should be done every 3-6k miles. While all the other posts maybe culprits too, lack of rotation would be the main problem.
Old Dec 15, 2011 | 07:07 PM
turboevo2's Avatar
turboevo2
Thanks guys will check the tire pressure and rotate it. My shocks are new HR cupkit
Toolman
Jan 20, 2016 06:50 AM
caiken
Aug 27, 2015 06:55 AM
Aug 19, 2015 12:51 PM
Kahnfucious
Aug 15, 2015 08:43 PM
