R56 Tire Sizes
Old Nov 29, 2011 | 08:03 AM
fullymooned's Avatar
fullymooned
Tire Sizes
Am looking to buy snow tires for my 2007 MCS preferably used. What are the sizes that fit. Tire rack says 195/55/16 and 205/45/17. Are there any other sizes that fit? Am hoping to spend around $300 for a set of 4 tires so am not too particular about the brand. Just something that will hold for 2 years or so.
Old Nov 29, 2011 | 10:23 AM
bluefox280's Avatar
bluefox280
Which diameter wheel? That's critical.
Because you've quoted both a 16" and 17" diameter tire.
- Erik
Old Nov 29, 2011 | 10:31 AM
fullymooned
The one on my car right now is 195/55/16. Am trying to find out all possible sizes that will fit.
Old Nov 29, 2011 | 10:37 AM
bluefox280's Avatar
bluefox280
So, there's a decent selection of 16" tires:
* 195/50-R16
* 205/45-R16
* 205/50-R16
* 185/55-R16
There's lots of choices available.
- Erik
Old Nov 29, 2011 | 10:42 AM
fullymooned
Got it. Thank you. I will look for tires of these sizes.
Old Nov 29, 2011 | 10:44 AM
Bilbo-Baggins's Avatar
Bilbo-Baggins
If you are looking to save money you should be looking a the smallest diameter wheel that will fit over the front brakes. Smaller wheel = cheaper tires
I do not think that you will find many 15" wheels that will fit over the 2007 MCS front brakes. However, there is this set of wheels available; http://nemini.org/index.php?topic=1941.0
They are a steal at that asking price. If I did not already have a set I'd be all over them.
Old Nov 29, 2011 | 10:46 AM
fullymooned
I cant open that link. It asks for username and password. Am looking to buy some cheap snow tires as I live in Cleveland, Ohio and it snows a lot here.
Bilbo-Baggins: I noticed you have quite a few mods that I like. Would you recommend Nokya yellow fog lights with PIAA xstreme white headlights?
Old Nov 29, 2011 | 01:59 PM
fullymooned
Will 205/55/16 fit?
Old Nov 29, 2011 | 02:15 PM
Bilbo-Baggins
The person is selling a set of four MINI OEM 15" wheels from an early 2009 that should fit your 2007. She is asking $300, complete with four good Michelin Alpine tires. Register on the nemini.org site, there is a lot of good things always happening there. A nice group of people, all dedicated MINIacs.
Definitely like the yellow fogs, much less glare than white or bluish colored beams. A little extra power in the headlights is almost always a good thing as long as you install the correct bulb and it is correctly aimed.
Old Nov 29, 2011 | 02:36 PM
Bilbo-Baggins
Will 205/55/16 fit?
You would be better off with 195/55R16. Narrower is always better in snow or on ice. The 205/55R16 would be a little taller but should still fit.
I run 185/65R15 for my snow tires. 205/50R16 for every day. 215/45R16 for auto-x and track events.
Old Nov 30, 2011 | 02:01 PM
fullymooned
I found someone selling Blizzak 205/45/R17 used on 2008 Clubman S. Will these tires fit the wheels of my 2007 MCS currently on 95/55/R16?
thank you.
Old Nov 30, 2011 | 02:50 PM
bluefox280's Avatar
bluefox280
I found someone selling Blizzak 205/45/R17 used on 2008 Clubman S. Will these tires fit the wheels of my 2007 MCS currently on 195/55/R16?
NO. The tire inner (mounting) diameter is different; you must have matching numbers.
You cannot mount a 17" tire on a 16" wheel.
- Erik
Old Nov 30, 2011 | 03:47 PM
Slave to Felines's Avatar
Slave to Felines
To clarify: If they are selling you the wheels and the tires together, they should fit.
If they are just selling the tires, you will have to find some 17" wheels to mount them on. They will not fit your 16" wheels.
Old Dec 1, 2011 | 06:11 AM
richardsperry's Avatar
richardsperry
And not to forget, with new wheels, you need to buy the tire pressure monitors too...
AND!!! Not to forget, but if you are just buying tires, don't forget that you will have to have them mounted and balanced on your wheels, so you can add about $100-$150 to the cost of the tires... AND you get to pay again to put the regular tires back on in the spring. You will kill snow tires in short order trying to use them when it's hot...
Old Dec 6, 2011 | 07:36 AM
fullymooned
Will these fit? They come with tires and wheels. My gut feeling is they are a bit small.
Owner says they will fit with wobble bolts. What are they and any disadvantages with them?
Old Dec 6, 2011 | 07:53 AM
cristo's Avatar
cristo
Alliance Member
14" wheels will not clear the brake calipers, and 185/60/14 will be way too short anyway.
185/60/16 would work, 195/60/15 would work, but make sure the 15" wheels will
clear the brakes (should be ok with your gen 1 with stock non-JCW brakes).
175/65/15, 185/65/15, 195/60/15 and 205/50/16, and 205/55/16 are also reasonable sizes.
Kimolaoha
Dec 5, 2020 09:32 PM
kazyn
Oct 25, 2019 02:34 PM
Waszak
Oct 21, 2017 05:55 PM
col127
Aug 21, 2015 02:11 PM
Edgar78
Aug 15, 2015 05:33 AM
