Navigation & Audio Power source for GPS hardwire install
Old Feb 17, 2004 | 02:42 PM
gnhovis's Avatar
gnhovis
Reverse
I've read various threads about aftermarket GPS installs and have come up with my own cunning plan. (Any Blackadder fans out there?...) I have an '04 MCS with the H/K head unit. I was reading about Nick Presley's XM install (http://nickpresley.com/xm/) and thought I could do something similar with my GPS.
I have a small magnetically mounted external antenna I could mount near the radio antenna, route the cable down to the stereo compartment in the back. For now, I'll route a cable up to the front along the center console to my Palm PDA. In the future, I will be using a Bluetooth GPS that will stay in the stereo compartment. What I need is 12vdc and ground to hook to my gps. (The cool thing about this GPS unit is that it powers the Palm as well so even if I upgrade to bluetooth, I'll still have to plug the Palm in somehow... Let's see, iPod, mobile phone, Palm: how much will one cigarette lighter socket take?)
So my question is how/where can I find power and ground inside the stereo compartment for use with my GPS and still be able to add a Blitzsafe unit for XM at a future date? Any advice appreciated.
GeorgeCo | GPS PDA Connectivity
Old Feb 17, 2004 | 06:04 PM
Smokey's Avatar
Smokey
Best bet, Add-a-Circuit
Clean and easy!
Ground can be found under the knee bolster, just to the left of the steering wheel there is a screw that can be used. Look at the Detector direct to Battery post for more methods.
What Blitzsafe model are you planning on using? I ask only because I know of none that would conflict with a power port / additional power mod up front. All Blitz's I know of are mounted in the trunk, and only require an imput cable to be run up front.
Good Luck
Old Feb 18, 2004 | 03:59 PM
Motoring's Avatar
Motoring
Mikeythemini at New MINI Stuff, a sponsor on MINI2 sells an adapter that plugs in between the factory deck and the factory wiring harness that provides a switched power and ground. Perfect for your use.
squawSkiBum
Oct 2, 2015 09:21 AM
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
Phantogram
Aug 12, 2015 12:11 PM
