R57 Just got an R57s... Is this normal?
Old Nov 17, 2011 | 08:23 PM
yervais's Avatar
yervais
Hello Guys... First post here, good to see such a nice mini community....
Well I just got a used 2010 R57 Mini Cooper S with 5k on the clock... and noticed the following...
A) Fuel Pump is too noisy.... I can barely hear it inside the car but outside its a bit noticeable... It sound electric... no failures or problems to start the engine at the moment.
B) Whirring/Vibrating sound when turning the AC on for a few seconds...
C) Auto Headlights stay on all the time... Seems like the sensor is not working (And I do have the Auto Headlights stalk switch) does it needs to be reprogrammed in order for it to work? I changed the battery when I took delivery because the car was dead...
D) Noisy Ride with the top-up... seems to be the top mechanism seals that touch the window... is there any way to make the top less noisy??
E) The car pulls from one side to the other (torque steer) on Wide Open Throttle... seems too unstable....
Well thats about it for the moment... I will appreciate any feedback!!
Thanks in Advance!
Y
Old Nov 19, 2011 | 10:25 AM
Matthieum's Avatar
Matthieum
For C and E that's normal. With day lights you have always the headlights on. Regarding the torque response in the stearing wheel, it is something "normal" for a Mini S or JCW. And it is even worst if the road is bad.
Old Nov 19, 2011 | 10:34 AM
yervais's Avatar
yervais
Thanks for the reply... But all the lights are on all the time with the auto function including the dials... You sure this is normal? How can I program it so that the stay fully off at daylight?
Old Nov 19, 2011 | 04:10 PM
Matthieum's Avatar
Matthieum
Do you have the GPS (I don't know how it works if you don't have it). If so, go to settings, if I'm not mistaken lighting, then you should have day lights. Turn it off. Keep your auto light on on the commodo.
It should turn on your lights when it's gettin darker.
I hope it's understandable.
Old Nov 19, 2011 | 04:30 PM
yervais's Avatar
yervais
Nope no gps... Is there anyway without gps?
Old Nov 20, 2011 | 04:50 AM
Matthieum's Avatar
Matthieum
You should be able to enter the setup by clicking on the button on the turn signal. When you get to the setting menu press the button for 5 seconds to enter the menu. You will be able to configure auto lock, and DRL. You have a logo that looks like to a headlight logo. Press again the button for 3 seconds to enter the sub menu. You will choose between yes or no.
Old Nov 22, 2011 | 08:34 AM
quality_sound's Avatar
quality_sound
And make sure the sensitivity on the auto headlights isn't all the way up.
Old Nov 23, 2011 | 06:23 PM
gr8ful's Avatar
gr8ful
Where did get the car?
Old Nov 27, 2011 | 03:39 PM
Bubble and Squeak's Avatar
Bubble and Squeak
Where is that setting? I have the Mini Connect. The only think I have on the blinker button thing is the Auto Whippers.
Old Nov 27, 2011 | 04:10 PM
rkw's Avatar
rkw
See this thread concerning daytime running lights: https://www.northamericanmotoring.co...ights-off.html
Old Nov 27, 2011 | 04:13 PM
quality_sound
I don't have Connect but I get to it through the stalk control. You'd have to read the manual to find out if yours is like that or if it's accessible through Connect.
Old Nov 30, 2011 | 11:50 AM
peeti's Avatar
peeti
D - there is a service bulletin on taking apart the lifting mechanism and installing felt to quiet some of it. If it's just the glass rubber interface though, you're SOL. No there is nothing you can do. Some have removed all grease with rubbing alcohol on both touching surfaces so they "stick" others lube (which is what your dealer will do if you complain about it). The lube is a silicone of some sort, it wears off in about two weeks. Really annoying.
E - welcome to FWD motoring. They had a software fix that applied to certain years and models though mine was ineligible.
Colt45Magnus
Aug 27, 2024 05:03 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
Shomare
39
Oct 19, 2015 03:33 PM
navybsn
Oct 4, 2015 03:27 PM
Miniwaukee
Sep 29, 2015 09:22 AM
