Suspension Koni yellows increase wheel gap?
Old Nov 15, 2011 | 06:14 PM
mini4tide's Avatar
mini4tide
After going from stock shock / H&R springs to Koni Yellows / same H&R springs, it appears the rear of my car sits higher now. Maybe 1/2 inch higher. Anyone else have this issue. They are installed correctly, and I am only a 1/4 turn from softest damper setting. It pisses me off, as my stance was perfect!
Old Nov 15, 2011 | 09:32 PM
Laardilla21's Avatar
Laardilla21
How long have you been running on them? I know when I redid the springs on mine, it took them a while to finally drop down...
Old Nov 15, 2011 | 09:34 PM
mini4tide's Avatar
mini4tide
Its been almost 2 weeks now. I'm hoping they settle a bit, before I yank them and get coilovers. Not really happy about it....
Old Nov 15, 2011 | 09:39 PM
Laardilla21
That is part of the reason why I am so on the fence about swapping out the shocks on mine. I love the current stance of the car and would hate to lose it because of springs. I would get coilovers, but I think they are overkill on a car like mine, which is a daily driver.
Old Nov 15, 2011 | 11:32 PM
mini4tide's Avatar
mini4tide
Yeah, the ride is great on the Koni's for sure. I had PSS9s on my Audi S4 and loved them! But they were very expensive!
Old Nov 16, 2011 | 08:45 AM
Laardilla21
Luckily, my car has the sport suspension, so I am REALLY hoping they last a bit longer than the standard ones with the lowering springs. Knowing my luck, they will go out at the same time the brakes are ready to get redone, as well. Talk about expensive. Hahaha...
Old Nov 16, 2011 | 09:08 AM
drewstermalloy's Avatar
drewstermalloy
I was going to say it usually takes a while for drop springs to settle, but seeing as you're using the same ones you had before I'm not so sure.
Old Nov 16, 2011 | 01:40 PM
claud's Avatar
claud
After a couple of thousand miles, mine looks stock. I did not see any change when I checked it out a week after install either. I have finally decided on my springs. I am going with JCW performance springs. Although almost twice as expensive as aftermarket, the small drop( .4 inch) is better for my DD needs.
Old Nov 17, 2011 | 09:27 AM
andyroo's Avatar
andyroo
There should not be a noticeable change in ride height from swapping to Koni Yellows.
- andrew
Old Nov 17, 2011 | 07:54 PM
mini4tide's Avatar
mini4tide
Its not horrible, but from what it was, it's noticeable. Its beginning to settle in though. Must just take a week or 2.
- andrew
sevin
May 2, 2026 06:11 AM
blackie
Aug 25, 2015 09:08 PM
Aug 21, 2015 11:25 AM
Emnotek
Aug 13, 2015 05:47 PM
mini yellow-haa!
Aug 13, 2015 11:18 AM
