R56 Help with Driving Light decision
Old Nov 11, 2011 | 05:02 PM
CFRM's Avatar
CFRM
I ordered the OEM driving lights last week. The dealer said he could connect them trough three separate ways.
1. When the brights go on.
2. When the Parking lights go on.
3. With the Fog Light Switch.
I'm leaning towards the Fog Light switch since I never run into thick fog, but that would Kill the purpose of the fog lights for good.
What would you do?
Cheers!
Old Nov 11, 2011 | 05:07 PM
CFRM's Avatar
CFRM
I should clarify that lighting isn't strictly regulated where I live, and all the options are legal. Even without modifications I can have ALL lights on at the same time without getting in trouble. But even then I'm always corteous with others around me
Old Nov 11, 2011 | 05:30 PM
ACEkraut11's Avatar
ACEkraut11
I would ask if a fourth were possible. On a separate switch. If not I would go with number 1.
Old Nov 11, 2011 | 11:44 PM
CFRM's Avatar
CFRM
Thanks for the input, I browsed a bit to see what the separate switch would look like. I would rather keep the clean look but I'll give it some thought.
Old Nov 12, 2011 | 07:49 AM
bluefox280's Avatar
bluefox280
I think what ACEkraut11 means to say is that the driving light switch should be independent from the headlight controls.
This can be done with a slight modification to the wiring harness to by-pass the 'trigger wire'.
However, you'll have to converse with your installing dealer to see what's allowed and viable by them.
- Erik
Old Nov 12, 2011 | 09:04 AM
RJKimbell's Avatar
RJKimbell
I thought there was a 2nd switch installed to the left of the Steering Wheel, according to minimotoringaccessories.com "...they work with the standard high beams and have a separate on/off switch for use at your discretion...", so basically you have 2 options for how you want to use them. I'll be having Molly's installed on her 4th Birthday in April!!
Old Nov 12, 2011 | 09:09 AM
ACEkraut11's Avatar
ACEkraut11
- Erik
True. Basically, any way possible to allow you to turn on the lights independently, whether that is with an integrated switch or one completely separate. My previous MCS had driving lights that had a switch on the knee bolster to power them and then they operated in conjunction with the bright lights.
Old Nov 12, 2011 | 11:09 AM
bluefox280's Avatar
bluefox280
Yes, that's the switch; but the wiring harness for the ligths are hooked into a module that only allows light activation when high-beams are present.
You can simply modify that harness to by-pass the "hi-beams only" activation.
- Erik
Wohnson89
Jun 10, 2020 04:53 AM
boostedhaze
Jan 2, 2018 07:26 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
