Suspension ???Power Steering Pump????
Old Oct 30, 2011 | 09:02 PM
MCMoto's Avatar
MCMoto
Ok, got my mini all back together, after having a whole new complete strut tower and sub- frame in-staled. Everything went back smoothly, but i have no power steering? Checked all wiring,? all looked good.. Hooked up a second pump to harness still no luck... How does this pump work??? It has the large harness (red and orange) positive and negative. And a small harness( 3 wire) two run through harness not sure where other disappears to??? Any way to test? send juice to? Not sure exactly how it is suppose to work? Sparks the first time you throw power to it then not again for a while..
Confused???
Also any ideas why fuel gauge barley moves off empty when turned on even if tank is full.????
MCMoto, Kansas
Old Oct 31, 2011 | 02:31 AM
HRM's Avatar
HRM
Just guessing you should check fuses and the big ground wire on the block.
Old Oct 31, 2011 | 06:16 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Yeah when sparks fly usually blown fuses are the end result......anytime you do something eletrical like this best to disconnect the battery .
A sending unit in the tank may be the cause of your fuel gauge being on the fritz.
Manny_cooper
Sep 10, 2015 11:09 AM
HaveATank
Sep 4, 2015 08:04 AM
Aug 25, 2015 09:33 AM
coachvminis
Aug 25, 2015 06:58 AM
minipopkart
Aug 13, 2015 05:22 AM
