Solo What class for 2007 MCS with/without mods?
Old Oct 26, 2011 | 12:17 PM
zpeedyz's Avatar
zpeedyz
I see many conflicting posts and SCCA sites regarding where my MINI should be placed. I want to run Novice for now, so I would imagine I would run NS. But after that, I see potentially that the R56 MCS should run in STX, but according to http://www.moutons.org/sccasolo/List...stockc.html#DS an R56 MCS should run in DS.
Now if I were to run with a tune and a rear swaybar, I believe that would definitely place me in STX. If I were to run without them, is DS, correct?
I'm in the San Francisco Region, and plan to run in Oakland this weekend, I'm just trying to figure out how to have my car registered properly and run in the proper group.
Thanks!
Old Oct 30, 2011 | 08:17 PM
Wiggles
Technically, a stock mini could run either class, but the appropriate class would be DStock.
Old Nov 6, 2011 | 01:19 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
D stock is correct and allows for you to use street tires but also stock wheels and R compound tires that will fit. This is a big advantage and gives you a good handicap for your class. Also you are stock so that works best.
STX is Street Touring and requires only street tires no R compound tires and it allows for more mods to suspension, brakes, intake, etc and worse handicap for the class.
You can run in either class depending on the level of competition you get.
You can even run in Street Modified F but will come up against highly modded front wheel drive cars. Still better than driving by yourself.
Old Nov 7, 2011 | 01:11 PM
dawgscj7's Avatar
dawgscj7
Run DS and get used to driving you car then make the jump to STX. You can't mod enough to compete in SMF, r56 mcs do great in DS on koni yellows w/ R comps, just food for thought
Old Nov 16, 2011 | 06:02 PM
adrive7's Avatar
adrive7
No Mods - DS
Rear Sway and Tune that does not change Boost levels - STX
Rear Sway and Tune that does change boost levels- DSP
Crazy go nuts - SMF
Old Nov 16, 2011 | 07:32 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
With the new rule change that just went into effect you can now run in stock class WITH an aftermarket rear sway bar. best rule change ever.
I would start in stock class with just the sway bar and see how far you want to go.
Old Nov 17, 2011 | 02:21 AM
adrive7's Avatar
adrive7
I assume thats the 2012 rules, so I'd hold off on that rear sway til next year. But I went looking for that change on the SCCA site and couldn't find it. Do you have a link to something?
EDIT: I found this: http://scca.cdn.racersites.com/prod/...k-nov-solo.pdf Which says you can change one or the other, but it says the change has simply been submitted to the BOD, not approved.
jetmechinnc
Nov 16, 2020 06:38 AM
Bea5tMa5ter
Aug 27, 2015 01:42 PM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
mini-medic
Aug 18, 2015 09:13 AM
massmini03
Aug 12, 2015 11:19 AM
