Interior/Exterior Rear Seat Delete
Old Oct 18, 2011 | 06:25 AM
martemchik's Avatar
martemchik
Rear Seat Delete
Anyone have any issues with any kind of rear seat delete kit? DIY or purchased? I'm looking into getting the one by Shrader but have heard people have issues like a warranty being voided or the airbag light goes on for no reason after the rear seat is out. Anyone that has done this please let me know.
Old Oct 18, 2011 | 07:13 AM
Erhan's Avatar
Erhan
I took my rear seats out as part of coilover installation for about a month ago. I haven't seen any airbag light coming on or any other issue. The car gets noisy due to lack of seats and trim. That being said, I'm not going to put my seats back. I will make a custom delete kit.
Old Oct 18, 2011 | 07:14 AM
Porthos's Avatar
Porthos
The only problem I had was that it came with covers to cover up the holes were the seats attach to the inside of the car and they don't fit. Also my friend that was helping me cut too much carpet away from were the back screw goes in. Other than that it takes about 20 to 30 minutes to do it and is totally worth it. I purchased mine from outmotoring.com they had the best price for one.
Old Oct 19, 2011 | 12:22 PM
xntrickly's Avatar
xntrickly
Pondering doing the same...
Is it possible to remove only one seat and leave one rear seat still in there?
thanks for any help.
Old Oct 19, 2011 | 01:51 PM
Erhan's Avatar
Erhan
No.
The bottom part of the seat if one piece. The back (folding) parts are 2 piece.
Old Oct 20, 2011 | 08:58 AM
xntrickly's Avatar
xntrickly
Thanks. In looking at the car last night I realized that having the bottom left in wouldn't be so bad. I'm trying to think of ways to transport my two racing bikes inside of the car instead of doing the tow hitch (which I'll do if I need to). I've removed the spare tire foam and everything so there's a lot of depth down there to rest the bicycle forks while the rear wheel goes backward toward the driver's seat. I'll think of something.
Cheers.
Originally Posted by Erhan
No.
Old Oct 20, 2011 | 09:17 AM
Porthos's Avatar
Porthos
MMM I don't know if I would do that. I would be afriad of tearing up the seats. Roof rack or a full rear seat delete would be a better idea. Plus I am pretty sure you have to take out the bottom part to get the backs off.
Old Jan 9, 2012 | 05:43 PM
selder's Avatar
selder
The backs just lift out, one at a time, takes about ten seconds.
the backs have nothing to do with the bottom except that they must come out before the bottom does. A nice thread:
http://www.miniacal.com/remove_rear_seats/
Have fun,
Steve
Old Jan 9, 2012 | 05:56 PM
dannyhavok's Avatar
dannyhavok
I took out the seatbacks and left the bottom in. I was after weight savings and all the weight is in the seat backs (first gen, anyway.) I've since replaced them since I like having a boot to hide stuff in when I'm parked. One upside (or downside, depending on your perspective.) is that the exhaust sounds louder with them out.
No issues with airbag lights or anything weird like that.
Old Jan 22, 2012 | 05:40 PM
madmaxxed's Avatar
madmaxxed
I made my own RSD for about $30.00. Looks more factory than the plastic one. I used dynamat to absorb or block out the added road noise. I haven't had any issues with airbags. I never hear of such a thing until this post. I would recommend saving some cash and doing it yourself. You will be much happier with the look once it's done. The longest part was allowing the glue to dry for the automotive carpeting.
Old Jan 28, 2012 | 05:18 AM
Hawk 06MCS's Avatar
Hawk 06MCS
How did you make your own RSD? I have a first Gen R53 and am wondering if this would work for me. Do you have any photos of the "Delete Install" process? A "How To" would be most helpful.
Old Jan 28, 2012 | 06:30 AM
d@g's Avatar
d@g
I believe the RSD airbag myth is an urban legend sourced to a drunken Aussie driving a right-hand car down-under who mistakenly performed a front-seat delete.
I need more room for the dogs in the back and the rear seats folded down still takes up a stupid amount of room. I took the seat-backs out to get some more floor-to-ceiling spaced, but it's still not what I want, which is a flat floor from front to back, much like Carbonized did with his car many years ago...
I'm not a huge fan of carbon fiber and it would be too slippery for the dogs, so I'm going to go with a simple fiberglass over plywood floor, covered with auto-fabric to match the car. I'd like to have a flat floor, so that means building in a hinged panel for the recessed portion over the toolkit.
Old Jan 28, 2012 | 07:47 AM
madmaxxed's Avatar
madmaxxed
I didn't take too many photos of the build process. It was simple though. I used a 1/4"X2'X4' board, 2 deck spindles, can of spray adhesive, and roll of automotive carpet. I found a DIY instructional post somewhere on this forum. I used it for the spindle measurements to lock the RSD into place. Other than that, the measurements were simple enough for the board. here is the link to the thread i posted with a few shots of the finished product.
https://www.northamericanmotoring.co...at-delete.html
Here is the link to the instructional post.
http://www.miniacal.com/rear_seat_delete/
Old Jan 28, 2012 | 01:31 PM
d@g's Avatar
d@g
Madmax, your car looks like mine inside (I have a Husky). Nice job on the home-made RSD. Certainly makes more sense than the commercially available one for $150. I still want mine to have a continuous flat floor, even though I'll lose a little height on the very back section. The dogs won't lay over the hi/low level change, but I think they'll do fine with a nice long (41") flat floor. Going the whole way and keeping it even, stable and secure will take some fabrication work, for sure.
Old Jan 28, 2012 | 02:56 PM
madmaxxed's Avatar
madmaxxed
I was also going to continue a removable rear portion but never got around to it. The RSD I built does have some flex just as the abs plastic originally would. Not any problem at all. My 133 pound Alaskan Malamute doesn't have an issue with the lower rear portion and loves the the added head room with the removal of the seats.
Old Feb 1, 2012 | 06:25 AM
cWade's Avatar
cWade
Rsd
I did this mod to my Mk I with no issues whatsoever. Great mod - hauled my Greyhounds and lots of stuff. Exhaust was a tad louder and it was a JCW. I would do it again.
Old Feb 1, 2012 | 06:30 AM
madmaxxed's Avatar
madmaxxed
I agree that the exhaust was a lot louder along with all the other under carriage road noise. I used dynamat and covered the entire area where the seat was. This did seem to help some. I love the simple mod though. The extra room is sooooooo useful.
mishanja
Jun 22, 2016 09:59 AM
06BLKchrgd
GP Talk (2006)
Feb 14, 2016 12:07 AM
Mini'mon
Aug 26, 2015 01:02 PM
mini4thewini
Aug 19, 2015 05:18 PM
The_Kid
Aug 18, 2015 06:50 PM
