R52 do I have a parking sensor?
Old Oct 2, 2011 | 04:36 PM
jdub2k5's Avatar
jdub2k5
I have every option for a 2005 that I know off (no nav or bluetooth) but
black panther leather
heated seats
digital ac
but I dont know if I have parking sensors, I have 4 dots on the back but they are painted orange
Old Oct 2, 2011 | 04:39 PM
daflake's Avatar
daflake
If you have the dots, you should have the sensors unless the bumper was replaced. When you put the car in reverse and backup you should hear a beep that gets faster as you get closer to an object.
Old Oct 2, 2011 | 06:33 PM
rkw's Avatar
rkw
Your 2005 cabrio has parking sensors as a standard feature. The dots are normally painted the same color as the bumper.
As daflake says, you should hear beeping as you back up close to an object. If you don't hear beeping, the fuse may be blown and you should get it checked (the fuse is shared with the power steering cooling fan which is a common failure).
Old Oct 2, 2011 | 08:49 PM
heli_guy's Avatar
heli_guy
As rkw stated, all cabrios have them. Check the fuse if you don't here the beeping, mine has blown several times. If it is blown, get the fan checked. I found sometimes small rocks get in there, and one it's cleaned cleaned out the fan works fine.
Old Oct 3, 2011 | 03:09 AM
daflake's Avatar
daflake
I didn't realize it was a standard feature on the cabrio.. Good to know!
Old Oct 3, 2011 | 04:22 AM
jdub2k5's Avatar
jdub2k5
thanks for the help guys which fuse is it?
I had to leave my mini in the parking lot at my work for 2 weeks while I am on the road(otr trucker)
I miss it and cant wait to tinker
Old Oct 3, 2011 | 09:00 AM
rkw's Avatar
rkw
On my 2006 cabrio it is fuse F41 (5A) in the drivers side footwell fusebox. Some people said it is F40 on their car, so it may be different depending on the year. Try it out first by backing up towards a wall. You should hear beeping when the bumper gets within a couple of feet.
Old Oct 3, 2011 | 06:09 PM
jdub2k5's Avatar
jdub2k5
thanks so much for your help, I got it fixed any idea on how to make it louder?
Old Oct 4, 2011 | 03:05 AM
daflake's Avatar
daflake
There is no volume control, that is as loud as it gets.
Old Oct 9, 2011 | 08:47 PM
rkw's Avatar
rkw
The parking sensor volume is a dealer programmable option, and it is mentioned in the Owner's Manual. However, according to this post: https://www.northamericanmotoring.co...le-option.html, the setting is 1-6 with a default of 5. Unless it had been changed previously, you only have one additional step. Personally I find the default volume to be almost too loud.
Old Oct 10, 2011 | 04:55 AM
daflake's Avatar
daflake
Totally forgot about that. Still, there is no easy way to do it and dealers charge way too much to reprogram it.
CRC
Dec 26, 2015 11:30 AM
Gen1Parts
Sep 7, 2015 03:50 PM
dandw2
Sep 7, 2015 11:14 AM
dandw2
Sep 6, 2015 03:14 PM
renchjeep
Sep 6, 2015 01:54 PM
