R50/53 Check/ fill S/C oil?
Old Sep 27, 2011 | 02:03 PM
Yyrd's Avatar
Yyrd
how to check or fill Supercharger oil/gear-lube?
Old Sep 27, 2011 | 03:18 PM
Baker555's Avatar
Baker555
I'm pretty sure it's a sealed unit. The only way to check/change the oil is to remove the s/c.
Old Sep 27, 2011 | 04:02 PM
element's Avatar
element
there are 2 sides.. pulley and waterpump
pulley - it's a hex scew right by the dipstick... you can open it fairly easy to check
waterpump - you need to pull the front end, SC and waterpump to get at it.. a bit of work, but if you plan on replacing your rad hoses, thermostat, etc it's not that bad.
I refilled mine, but it makes a new noise now and think the bearings are slowly going.. after 140k miles
phil.
Old Sep 27, 2011 | 06:10 PM
LAMARR -s53's Avatar
LAMARR -s53
so u can check it ? or is it sealed ?
Old Sep 27, 2011 | 06:22 PM
ACallahan's Avatar
ACallahan
A talented person in our MINI community has recently put a DIY together for this.
http://www.focusoa.com/MINI/supercha...rgerDoc_v3.pdf
Old Sep 27, 2011 | 06:39 PM
veggivet's Avatar
veggivet
That is an amazing writeup and worthy of a place in my MINI Maintenance folder.
Old Sep 27, 2011 | 06:49 PM
FerrariMX5's Avatar
FerrariMX5
So, how much would a knowledgeable and competent shop charge for this little bit of normal maintenance?
Trying to get a good idea of the cost benefit at 62,000 miles
Old Sep 27, 2011 | 07:48 PM
ACallahan's Avatar
ACallahan
I know of a shop in the Largo/ St.Pete area that does it I think for about $275
DixonL2
Apr 13, 2021 08:05 AM
desant89
R55 :: Clubman Talk (2008+)
Sep 2, 2015 11:24 AM
RACEnSK8
Sep 1, 2015 09:33 AM
Camaro108
Aug 25, 2015 02:44 PM
Steffen.Johnson
Aug 23, 2015 08:30 PM
