Suspension Alot of help !!
Old Sep 15, 2011 | 07:31 PM
nemeth's Avatar
nemeth
Alot of help !!
hey guys. im brand new here. i pick my car up over the weekend. i wanted to know a few things. coilovers vs springs. any and sway bars needed ? and anyone have anything that is really really reliable ? thanks guys
Old Sep 15, 2011 | 09:42 PM
bluefox280's Avatar
bluefox280
Depends on your intended use.
Do you want a spring set that you install and don't have / want to tinker with (like a set-it-and-forget-it modification)?
Or do you want to be able to corner-balance with spring preload and set you own ride height?
Again, depends on application.
Do you like the car to understeer or throttle lift-induced oversteer?
Typically, a rear sway is done first to flatten out the body roll and reduce a heavy understeer condition.
For which component? You've opened a huge can of worms as there's several different combinations ranging in price and application.
First, determine what you like and don't like about the handling characteristics on the car and advance your selection accordingly.
- Erik
Old Sep 15, 2011 | 09:48 PM
nemeth's Avatar
nemeth
i would like to have the set and forget type, and the throttle life induced sounds about right. and i want something, that will lower my car. im guna have 17's on it. i pick i up saturday. and i wanna forget about it completely. wanna have it look nice.
Old Sep 15, 2011 | 10:01 PM
bluefox280's Avatar
bluefox280
Then a set of lowering springs and a set of performance struts / shocks are the way to go.
There are several spring options including: NM-Engineering, Eibach, H&R, etc.
And several options of struts / shocks: Koni, Bilstein, etc, etc.
...and the throttle life induced sounds about right.
Then a increased diameter rear sway bar is what you're looking for.
Again, several choices based on solid vs. hollow, mounting bracket style, etc.
There's a lot of archived info and photos on peoples set-ups; search the suspension sub-forum, and the wheel and tire forum.
- Erik
Old Sep 15, 2011 | 10:28 PM
nemeth's Avatar
nemeth
i got no idea what any of it means. doing research. thanks for the help !! appreciate it
Old Sep 16, 2011 | 06:24 AM
veggivet's Avatar
veggivet
First thing you should do is replace the run flats with a set of performance tires, and dedicated winter set if you need snow tires where you live.
USNAE2
16
Jun 17, 2022 07:17 AM
Doc Pain
Oct 28, 2015 07:09 PM
Jerome R Jr W
Sep 29, 2015 11:42 AM
Marioalex24
Sep 21, 2015 11:08 AM
Doc Pain
Sep 15, 2015 11:31 PM
