Suspension Sway Bar Specs found
Old Sep 6, 2011 | 12:17 PM
OKCdancer's Avatar
OKCdancer
Sway Bar Specs from another site as follows:
FRONT
Standard: 22.5 mm
Sport: 23.5 mm
JCW retrofit: 24 mm
REAR
Standard: 17 mm
Sport: 18 mm
JCW retrofit: 18.5 mm
Old Sep 6, 2011 | 12:21 PM
OKCdancer's Avatar
OKCdancer
Further findings...
These are the figures for the stabilizers on the Cooper S:
FRONT
Standard: 22.5 mm
Sport: 23.5 mm
JCW retrofit: 24 mm
REAR
Standard: 17 mm
Sport: 18 mm
The figures for the Cooper is:
FRONT
Standard: 21.5 mm
Sport: 23.5 mm
JCW retrofit: 24 mm
REAR
Standard: 16 mm
Sport: 18 mm
Old Sep 11, 2011 | 03:51 PM
irishpunk's Avatar
irishpunk
Thanks!
Old Sep 11, 2011 | 04:50 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I wouldn't trust those to be 100% accurate. As I've found when removing and actually measuring the bars those specs are not always true. You need to measure your actual bar to know what you really have.
Old Sep 19, 2011 | 05:58 AM
honda93's Avatar
honda93
Subscribed. Thanks!
Old Oct 8, 2011 | 05:34 AM
SMOG's Avatar
SMOG
Alliance Member
I would 2nd this thought!
My "Sport Suspension" on my 2011 R-56 MCS came with an 18.6mm rear bar.
Old May 16, 2012 | 07:50 PM
Big Jim Swade's Avatar
Big Jim Swade
Does anyone know what the part number is for the 18.5mm JCW Suspension kit rear bar is?
Old May 17, 2012 | 07:35 AM
Dozuki01's Avatar
Dozuki01
Urethan Bushings kit - Recommendation
Would it be possible for you to compile a Urethane bushings kit together for improving steering responses, suspensions, sway bar, end link, etc. instead of OEM bushings.
Old May 17, 2012 | 08:18 AM
Big Jim Swade
Having delt with Urethane bushings before on other cars, I'll never use them again. Rubber bushings are totally maintenance free with no creaking or greasing.
Old May 17, 2012 | 08:24 AM
Dozuki01's Avatar
Dozuki01
Oh, really? thanks for the feed back. My Clubman is a 2009 MCS CPO's and I wanted a bit more firm for the handling. Right now just a bit too soft, dipping left and right... etc.
Any ideas...
Old May 30, 2012 | 03:24 PM
Big Jim Swade
I finally found out the part number for the 18.5mm JCW rear bar is
33556782723 and it uses the same bushings as the 18mm bar from a car with the sports suspension. The bushing part number is 33556772788.
If anyone is interested
www.minipartsmass.com has the rear bar for $102.
The part numbers are very difficult to find on realoem because they are listed under the "Front Axle Accessories and Retrofittings"
Mini7
Feb 2, 2016 07:52 PM
Bennyboy
Aug 18, 2015 07:28 AM
minipopkart
Aug 13, 2015 05:22 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
