R50/53 R53 Passenger Brake Light Problem
Old Sep 4, 2011 | 11:12 PM
jayzersmini's Avatar
jayzersmini
Hey All.... I am a new Mini owner and new to the forum so if I have posted incorrectly my apologies. I have a 04 cooper s just came out of the shop passenger brake light not working but drivers side is. 700.00 fix BCM needs to be replaced and right now cash is tight. I was told I could jump the wire from the drivers side brake light wire to the passengers side... for a temp fix. If this is true which wires on the harness on the back of the lamp board control the "Brake" control light..... I could not find a diagram anywhere online.
Old Sep 5, 2011 | 01:17 AM
BigFox's Avatar
BigFox
Id have to say, this does not sound like a good idea.... I've seen it done, and if you want your MCS to look all hooptie inside, then go right ahead, but seriously, just replace the BCM. Its only gonna get worse. And they need to address the sunroof drains at the same time, or it will kill the next one too......
BigFox's Avatar
BigFox
If you want the wiring, I can get if for you, just PM me and ill shoot it over to you
Old Sep 5, 2011 | 05:10 AM
RGCOOPER's Avatar
RGCOOPER
I jumped mine and it works fine.
You should replace the bulbs with LED's.
If you don't, adding the extra bulb to the circuit may burn out the driver side of the BCM.
iggi
18
Feb 9, 2026 01:00 AM
Zettinger
Aug 25, 2015 04:04 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
