R50/53 Sunroof track adjustment
Old Aug 29, 2011 | 02:51 PM
DMBFan2's Avatar
DMBFan2
I have an 03S and the sunroof on the front passenger side is loose inside of the track. I can move it up and down about 1/8". When I go over a bump it makes a loud "thud" noise. Is there a way to adjust it?
Adjusting the torx screws only adjusts the window. Its the actual track that it rests inside that is loose.
Thanks in advance.
Old Sep 4, 2011 | 11:43 AM
DMBFan2's Avatar
DMBFan2
Anyone?..........
Old Sep 6, 2011 | 01:16 PM
beken's Avatar
beken
Sorry, I've never done it myself, but my dealer has taken the entire thing apart and fixed it under warranty once. It seems it was a common issue and there is a fix for it. Mine wasn't rattling at the time, but the service rep told me to complain about it anyways so they could cover it under warranty.
Old Sep 6, 2011 | 02:20 PM
lambspeed's Avatar
lambspeed
when you pull the interior trim around the rear portion of glass, gently pull down on the headliner. looking towards the rear of the car left and right side you will see two hexagonal nuts. about 7/8 i think. And they are very thin in size. they will tighten the sun roof. try the side that is loose first. then check if sunroof glass is not pulling to one side. I eliminated the creeks in my roof by just turning them both about a 1/4 turn.
Old Sep 6, 2011 | 07:01 PM
DMBFan2's Avatar
DMBFan2
I will give it a try!!!
Thanks!
Old Oct 8, 2011 | 02:27 PM
DMBFan2's Avatar
DMBFan2
I tried that. They were a liitle loose. Maybe tightened a bit but not much. The following YouTube is what I mean. It is the passenger side sunroof. The sunroof is loose INSIDE of the track.
http://www.youtube.com/watch?v=pYXR-A68Ee0
Tahnks for helping out.
Old Oct 12, 2011 | 10:34 PM
DMBFan2's Avatar
DMBFan2
Anyone?!!!
Everyday this sunroof gets more and more loose!!!! For now, it is left fully closed.
Old Jun 15, 2012 | 04:18 PM
just.'s Avatar
just.
update? ?
Has anyone found a solution many in mini north have the issue.
ToyCar
Nov 19, 2023 05:20 AM
Filmy
15
Jun 6, 2023 06:27 AM
patsum
26
May 29, 2021 06:29 PM
hockeydad51
Oct 9, 2015 01:51 PM
Colt45Magnus
Sep 14, 2015 03:12 AM
