R50/53 Check Engine Light!!! O2 SENSOR --- P0136 CODE
Old Aug 11, 2011 | 01:42 PM
androidphil's Avatar
androidphil
Did a bit of searching in the old threads, but, the search function on this site is horrible!!! Anyway, had the CEL come on on my fiance' the other day and used my OBDII scanner to pull the code. P0136 "O2 SENSOR MALFUNCTION (BANK 1 SENSOR 2)". Called the MINI dealer and found that most of the 04-06 MINI S's the O2 sensor warannty was extended to 100,000 mile due to issues, cheaper than a recall i guess. BUT, I'm at 104k!!! DAMN! so, question is.... WHO HAS REPLACED THIER O2 SENSOR? What did you use? Dealer part is $299.99. What a rip! Found a new OEM part for $200, but, that is as cheap as Ive found. There are some universal sensors from BOSCH online that would fit, but just have to wonder if they are junk. I have posted a screenshot from my phone of the TORQUE SCAN TOOL I use. If you have never heard of TORQUE for ANDROID, you should check it out... SO COOL!!! WORKS AWESOME!!! Anyway, thanks for the help...
P.S. I know that out MINI's use two of the same O2 sensors in the setup...
What sensor should I replace?
Attached Thumbnails Check Engine Light!!! O2 SENSOR --- P0136 CODE-sc20110809-191517.jpg
Old Aug 11, 2011 | 11:16 PM
BlwnAway's Avatar
BlwnAway
Yes both sensors are the same, your code is indicating "post cat" , from what I know you want to use the bosh plug & play replacement (oem), not the universal. (you'll have issues).
As far as price, shop around, give Chad or Way a call.
Old Aug 14, 2011 | 07:29 PM
ghurm001's Avatar
ghurm001
definitely go with the plug-and-play variety.. I worked through three different universal ones trying to get them to work. If I remember correctly, I ended up finding one with the wire and the plug on the end of it for like $150 somewhere. I think maybe ECStuning. try this http://www.ecstuning.com/ES2019579/
Old Jun 18, 2014 | 07:56 AM
Teh_Burninator's Avatar
Teh_Burninator
If anyone's looking for the O2 sensor, check Rock Auto. I found the Bosch with the wire and plug for about $88 there.
Old Jun 18, 2014 | 09:04 AM
astroBlackMetallic_Mini's Avatar
BlwnAway,
you sure its Post cat? thought that was the p0420 code (i am currently throwing)... or is it a separate code for a Failed sensor vs failed cat? (assuming it is, now that i think about it)
Old Jun 18, 2014 | 10:29 AM
GreekDrifter91's Avatar
GreekDrifter91
go to rock auto they have them the cheapest 80 or 90...
and yes astro they are two diffrent codes for cat below efficency and 02 failire/circuit bad.
Old Jun 18, 2014 | 11:56 AM
ZippyNH's Avatar
ZippyNH
P0420 Catalyst System Efficiency Below Threshold
P0421 Warm Up Catalyst Efficiency Below Threshold
P0422 Main Catalyst Efficiency Below Threshold
P0423 Heated Catalyst Efficiency Below Threshold
P0424 Heated Catalyst Temperature Below Threshold
P0425 Catalyst Temperature Sensor
P0426 Catalyst Temperature Sensor Range/Performance
P0427 Catalyst Temperature Sensor Low
P0428 Catalyst Temperature Sensor High
P0429 Catalyst Heater Control Circuit
P0430 Catalyst System Efficiency Below Threshold
P0431 Warm Up Catalyst Efficiency Below Threshold
P0432 Main Catalyst Efficiency Below Threshold
P0433 Heated Catalyst Efficiency Below Threshold
P0434 Heated Catalyst Temperature Below Threshold
P0435 Catalyst Temperature Sensor
P0436 Catalyst Temperature Sensor Range/Performance
P0437 Catalyst Temperature Sensor Low
P0438 Catalyst Temperature Sensor High
P0439 Catalyst Heater Control Circuit
Read more: http://www.*********************/lib...#ixzz351DTzSva
and
P0130 O2 Sensor Circuit
P0131 O2 Sensor Circuit Low Voltage
P0132 O2 Sensor Circuit High Voltage
P0133 O2 Sensor Circuit Slow Response
P0134 O2 Sensor Circuit No Activity Detected
P0135 O2 Sensor Heater Circuit
P0136 O2 Sensor Circuit
P0137 O2 Sensor Circuit Low Voltage
P0138 O2 Sensor Circuit High Voltage
P0139 O2 Sensor Circuit Slow Response
P0140 O2 Sensor Circuit No Activity Detected
P0141 O2 Sensor Heater Circuit
P0142 O2 Sensor Circuit
P0143 O2 Sensor Circuit Low Voltage
P0144 O2 Sensor Circuit High Voltage
P0145 O2 Sensor Circuit Slow Response
P0146 O2 Sensor Circuit No Activity Detected
P0147 O2 Sensor Heater Circuit
Read more: http://www.*********************/lib...#ixzz351Dqe1yN
Here is the list..or part of it!!
Old Jun 18, 2014 | 01:33 PM
Stoker's Avatar
Stoker
Use Google to search the site..
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
massmini03
Aug 12, 2015 11:19 AM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
