Interior/Exterior Need Help: How to mount Morimoto mini H1's. Tight Squeeze.
Old Jul 30, 2011 | 02:44 PM
bmwboyee's Avatar
bmwboyee
So here are the details first:
Headlight: Mini Cooper R56
Projector: Morimoto Mini H1
Shroud: Mini Gatling (only one that will fit)
Bulb Base: H7
Here is my problem, the light is so cramped in there the easy way to mount the Mini H1 isn't working. there just doesn't seem to be enough room. The lens comes down and rubs on the shroud and there is a lot of room after the shroud that is noticeable. Here is a picture:
Picture from the back:
Picture of a stock Mini Cooper Xenon (notice how far back the projector sits):
Notice where mine sits:
I was thinking about slicing the back side of the reflector and making "extensions" to pull it back and jb weld the extension part so I could keep the mounting. I'm sorta clueless though on what to do because that is why I bought the Mini H1's because of ease of install.
Any help would be greatly appreciated.
Old Jul 31, 2011 | 06:26 PM
XXLil MickXX's Avatar
XXLil MickXX
The photo you posted as reference looks like a first gen HL. Yours looks like a second gen light so best to repost your thread in 2nd Gen. If you do have a gen 1 I have an extra left HL if you need spare parts..
Old Jul 31, 2011 | 06:53 PM
bmwboyee's Avatar
bmwboyee
thanks for that. i completely forgot. I have a R53 and my first instinct is to post here. lol. thanks.
Old Aug 2, 2011 | 06:51 AM
yetti96's Avatar
yetti96
I had to cut a ton on the back just to get the bet of the projector to sit back in there. I also had to cut almost 1/3 of my shroud to make it fit with the now-recessed projector. I used the D2S projectors (slightly bigger) on my R56.
Old Aug 2, 2011 | 12:39 PM
bmwboyee's Avatar
bmwboyee
Do you have any pictures of your lights and back of housing?
Old Nov 12, 2011 | 07:16 AM
NH_MCS's Avatar
NH_MCS
Would you be able to fit the Mini H1 in there without the shroud and be able to fit the headlight lens back on?
Old Nov 12, 2011 | 07:46 AM
bmwboyee's Avatar
bmwboyee
maybe but it would look horrible. I ended up cutting the back of the reflector to accept the projector. I also JB Welded it to the reflector and if I had to do it again would use screws and bolts.
Old Nov 13, 2011 | 05:23 AM
NH_MCS's Avatar
NH_MCS
Well I had a different idea about fabricating a shround that would be very slim and still cover the visible parts of the projector. Just wanted to see if they'd fit with the lock-ring mounting method w/o shroud.
Old Nov 13, 2011 | 12:27 PM
bmwboyee's Avatar
bmwboyee
You're not going to have enough clearance to do that I don't believe if you don't cut the reflector.
On another note, I have 4 sets of these projectors. They are Gen III and what you see in the pic are Gen IV's. The difference is a painted cut off shield (which does nothing imo) and an outer chrome housing.
(2) sets perfect - $70 shipped
(2) sets small blems (I mean very small, i'm picky) - $55 shipped
Just if anyone is interested.
wheresaldo
Oct 23, 2015 10:17 AM
Mini'mon
Aug 16, 2015 12:47 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
bleonard1401
R60/R61 Stock Problems/Issues
Aug 10, 2015 02:15 PM
