Brake pedal click/clack when in Park
Old Jul 19, 2011 | 05:11 PM
Cosmic Blue Conspiracy's Avatar
New problem (they keep piling up). When in Park, depressing the brake makes an audible click like a marble or ball dropping which you feel in the shifter. This started today.
Old Jul 19, 2011 | 08:06 PM
ChefTyler's Avatar
ChefTyler
That would be the release allowing you to shift out of Park. Most automatics have this sensation...the lock makes it so you have the brake depressed when shifting, since shifting out of Park without the brake on is kinda...dangerous.
Old Jul 20, 2011 | 07:47 AM
Let me be clearer. This is something that hasn't happened until today. It's not the "ping" you get when you actually shift. It's literally when I am in park, if I depress the brake and then let up the brake, I get the clack which I feel in the shifter. I've had the car for almost 10K miles and this just started today. Does anyone else have that sensation? Again, started today, and when I had the service loaner, it wasn't there, either.
Old Jul 20, 2011 | 11:42 AM
ChefTyler's Avatar
ChefTyler
Call the dealer and ask, but I can tell you this, I have felt and heard that in EVERY automatic I've ever owned/driven. If it just started after 10k miles, then something likely got broken in.
Perhaps my explanation wasn't enough. There is a lock of some sort (usually a gate) that locks the shifter in place when it's in Park. This lock doesn't release until you hit the brake, and when you let off the brake the lock goes back in place. In most automatics this produces an audible click and a vibration that is felt in the shifter.
Old Jul 20, 2011 | 03:02 PM
HRM's Avatar
HRM
Correct.
Shift lock solenoid. That is the thing that keeps it from shifting out of park until you depress the brake pedal. It may just be louder for some reason or you just never noticed. The adjustment could have moved a bit to change the noise...but it isn't major that is for certain. Often there is an override where you can stick a key in incase it goes bad on the road. Probably in the manual, but I have a stick stick so I don't even know what the console looks like.
Old Jan 5, 2013 | 12:08 AM
nwmini26's Avatar
nwmini26
Resolution
Hello Cosmic,
this very thing happened to me today. Can you tell me what eventually happened to the click/clack?
thanks
Old Jun 29, 2013 | 11:02 AM
David Alfaro's Avatar
David Alfaro
I have the same problem with my R60 ALL4 2013. Took it to the dealer and they told me its a "normal" noise. That it will not damage anything, and it had to do with the parking mechanism... I really didn't understand everything.
But they told me it will not affect anything.
Old Apr 20, 2015 | 07:16 PM
BirdofPrey's Avatar
BirdofPrey
Calling BS on the click
Had my brakes serviced today, and out of nowhere I'm getting this loud clicking that is so loud it vibrates through the auto gear shifter and emergency brake from the brake. The dealer says, "every car does this"...I have been driving for 28 years and never experienced this. Sounds like a joint popping and out of socket. This is NOT normal.
Old Jul 26, 2015 | 09:07 AM
S4SF's Avatar
S4SF
My 2015 CM S does this. 556 miles on it. ChefTyler nailed this right away. Normal. If anyone doubts it, hop in another Mini. Guaranteed it will do the same thing. The noise may be more noticeable on some cars than others. Naturally, people tend to notice things about their car when they leave a shop.
Old Jul 26, 2015 | 08:27 PM
BirdofPrey's Avatar
BirdofPrey
Not to belabor the point, but my clicking sound and the noise disappeared once I put on all new rotors. Just my experience. Your mileage may vary.
Old May 12, 2017 | 06:37 PM
mvt888's Avatar
mvt888
Same on my F56 (42k miles), I just noticed it today. Exactly as you described. Engine running and in Park or N. No sound Engine off. Also clicks at very low speeds 1-5mph coasting in Neutral (but not in Drive). Perhaps the sound was always there but I never noticed, or perhaps coincidentally, I starting to notice it having just flushed my brake fluids and more keen on sounds and noises, to confirm whether or not I did something wrong.
Old May 12, 2017 | 08:33 PM
mikey_t's Avatar
mikey_t
Look at the date on those prior posts....
Old Dec 29, 2021 | 01:37 PM
stiksandstones's Avatar
stiksandstones
@Cosmic Blue Conspiracy I know this thread is 10 years old hahaha, but, I have this newly developed sound too (yes I was in the shifter/idrive compartment installing some wires) but I never noticed it before and I certainly altered something-super annoying-anyone ever find a solution?
theblackfalcon
Oct 11, 2015 09:49 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
Powershift
Aug 16, 2015 05:14 PM
