R50/53 Hatch is closing oddly
Old Jul 8, 2011 | 04:08 PM
Curbiecooper's Avatar
Curbiecooper
I noticed a couple weeks ago that the hatch was shutting a little different then before. When you shut it, it closes more off to one side then leaving a gap on the other side and top half of the hatch.
So I am wondering if maybe someone else has had this problem and knows how it may be fixed ???
Curbies worried owner
Old Jul 8, 2011 | 04:23 PM
JAB 67's Avatar
JAB 67
Check the hinges. Do a search on 'hatch hinge failure' or similar words.
Old Aug 1, 2011 | 06:36 PM
rallymaniac's Avatar
rallymaniac
I'm having the same issue. It started today,
Now the hatch barely closes with left side almost touching the opening (no gap at all) and huge gap on right side. The right side also is a bit lower and outward.
The weather strip on the window shows that the hatch is clearly misaligned.
Old Aug 2, 2011 | 08:43 AM
MINIdave's Avatar
MINIdave
Lube your hinges.
But it's probably too late and you'll have to replace one or both.....
Old Aug 3, 2011 | 05:54 AM
DixonL2's Avatar
DixonL2
Hinges are a wear item, apparently.
Old Aug 3, 2011 | 10:35 AM
r53tuning's Avatar
r53tuning
Yeah the hinges are known to rust and eventually break. Some dealer's cover this under warranty depending on year/mileage of vehicle.
Old Aug 3, 2011 | 01:18 PM
ZippyNH's Avatar
ZippyNH
Remember the rubber bumpers (on the hatch) can twist to adjust how the hatch seats...check it first. One of them might have gotten bumped, or the weatherstripping might be getting loose, and causing interference....since the hinges are $$, I'd rule out the simple stuff.
OutMotoring
Mar 3, 2017 06:29 AM
Fordgt4
Oct 10, 2015 10:42 AM
eMINI of the State
Oct 2, 2015 03:12 PM
Huskyfan
GP Talk
Sep 28, 2015 06:08 PM
daviday
Sep 25, 2015 01:31 AM
