Front bumper light question
Old Jul 3, 2011 | 04:55 PM
Hot Shot's Avatar
Hot Shot
One of my lights is out in my front bumper. It's the passenger side round light that houses the turn signal also. The small white light on the outside of the light is out. I pulled the plug, but cannot get the bulb out? Anyone have an idea on how to get it out? Does the bumper have to come off? My car is a 2004 if that matters.
Thanks,
James
Old Jul 3, 2011 | 05:36 PM
rkw's Avatar
rkw
Just twist to release the bulb holder from the light housing. If it was never removed before, it can be stuck very tight and difficult to twist (might even need pliers to get enough grip). You can make more room for your hand and a better grip if you undo the turn signal bulb holder first (also twist). The bulb size is 194.
No need to remove the bumper. Just open the hood and reach down.
Old Jul 3, 2011 | 05:48 PM
Hot Shot's Avatar
Hot Shot
Thanks. I'll try pulling the turn signal bulb first and see if that helps. I'll try some pliers after that.
~James
Old Jul 3, 2011 | 06:54 PM
Hot Shot's Avatar
Hot Shot
I did get it out by removing the turn signal bulb, then using a pair of pliers to get it turned enough to where I could finish pulling it out by hand. The funny thing is when I pulled it out and looked at it, it looked fine. I plugged it back in and it works fine now. I bought a pack of spares just in case.
Thanks,
James
silence2-38554
Nov 12, 2015 09:39 AM
smlzilla
Aug 14, 2015 07:00 PM
JHolland
Aug 13, 2015 10:47 PM
skippermini
Aug 12, 2015 10:05 PM
