Drivetrain RMW's new race inspired CAI
Old Jun 30, 2011 | 07:49 AM
Revolution Mini Works's Avatar
Having the need for a 3" inlet for our big Rotrex kit we decided to build something that hasn't been done. We have seen 20-40hp restrictions with cone filters on the big Rotrex's when pushed hard. Over 400hp
So having said that here is the first design...............
Old Jun 30, 2011 | 08:18 AM
mini_macky's Avatar
mini_macky
So...the last pic would be what you'd see if you're on the driver's seat & can see through the firewall?
Old Jun 30, 2011 | 08:28 AM
dannyhavok's Avatar
dannyhavok
I believe that the last pic shows the view you would see standing on the drivers side of the open bonnet. You can see the cowl vents on the right hand side of the photo.
the last picture was taken from the LHD side
the box sits in the normal location
we will be offering one up with a 2.5" hose version later for the new superchargers we have coming and also the 3" version
Old Jun 30, 2011 | 08:49 AM
mini_macky's Avatar
mini_macky
I think I scrolled down & typed too fast as the last pic that popped up before I replied was the pic of the filter
So with the box mounted, the huge filter is angled downward?
Old Jun 30, 2011 | 09:49 AM
yes, it allows a bigger filter for the space
there is also area after it to straighten out before going into the velocity stack
Old Jun 30, 2011 | 11:15 AM
JumpingJackFlash's Avatar
JumpingJackFlash
I don't imagine there is much restriction on a Stage I MINI S setup (15%, DDMWorks CAI, exhaust, tune). However, I'm sure that helps out your big MINI project a good bit. Nice design.
Old Jun 30, 2011 | 12:12 PM
gothmdoc's Avatar
gothmdoc
interesting... any hint of when you will begin marketing this?
Old Jun 30, 2011 | 12:19 PM
right, we are not worried about the units with the stock chargers........as Mini was smart enough to make an airbox worthy.......however on our TVS900 kits that will be coming out, you will need a better flowing box all the way up to 3" design, hence the start of building something that will work
it's only currently for the 1st gen Mini's
we may however make something for the R56s
Old Jun 30, 2011 | 12:52 PM
Now to make sure the heat is reflected away from the box to keep it as cool as possible
Old Jun 30, 2011 | 01:12 PM
JumpingJackFlash
Yes, the heat reflective material should definitely help out. Man, you've been watching NASA TV alot lately.
Old Jun 30, 2011 | 02:02 PM
minimarks's Avatar
minimarks
Good stuff!!!
Old Jun 30, 2011 | 02:55 PM
LüDICRöüS's Avatar
LüDICRöüS
Old Jun 30, 2011 | 04:03 PM
tlr1000's Avatar
tlr1000
It looks too small...needs to be bigger
Seriously, that thing looks massive. Nice work.
Old Jun 30, 2011 | 04:08 PM
actually it's not that big except the fact it's 3" outlet. We had one on the dyno running 1100hp Drag honda with the same design and the filter was about 2" longer and 1 in wider
Old Jun 30, 2011 | 04:46 PM
tlr1000's Avatar
tlr1000
Does that panel air filter have more surface area than typical cone ones used on most R53 CAIs?
Old Jun 30, 2011 | 06:37 PM
OldGameFreaK's Avatar
OldGameFreaK
Will a strut bar still fit with it?
Old Jun 30, 2011 | 07:14 PM
Old Jun 30, 2011 | 10:04 PM
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
Like! how much? loud?
Old Jun 30, 2011 | 11:02 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
I actually had about the same idea cross my mind, when I wasn't sitting behind a desk in Iraq, I decided against building the thing though, because even with a 3 inch opening at the intake, my throttlebody is only 63mm, and with the length and smoothness of the intake tube, you could have a 5 inch pipe and not gain a single HP IMHO.
Old Jun 30, 2011 | 11:31 PM
ggcadc's Avatar
ggcadc
sure DG, thats the problem if your using the stock TB and everything after... but i think that problem may have been thought through already
I like the looks, wish I had the need for it...
Old Jul 1, 2011 | 05:11 AM
davisflyer's Avatar
davisflyer
Old Jul 1, 2011 | 06:10 AM
thanks Davis..........at least someone can read and follow along........lol
I think I will hear rumbling in the back ground today............I hope to be at VIR on July 22nd...... you plan on stopping by?
Old Jul 1, 2011 | 07:14 AM
jhiggs26's Avatar
jhiggs26
Very nice Jan. Will there be an input for stock front air feed for stocker intake boxes?
Good news about the TVS900!
Jeremy
Old Jul 1, 2011 | 07:26 AM
Jeremy
yes but this was designed for my car for testing
with all the piping in my car there wasn't any room
