North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Drivetrain (Cooper S) (https://www.northamericanmotoring.com/forums/drivetrain-cooper-s-16/)
-   -   Drivetrain RMW's new race inspired CAI (https://www.northamericanmotoring.com/forums/drivetrain-cooper-s/213257-rmws-new-race-inspired-cai.html)
Revolution Mini Works Jun 30, 2011 07:49 AM
Having the need for a 3" inlet for our big Rotrex kit we decided to build something that hasn't been done. We have seen 20-40hp restrictions with cone filters on the big Rotrex's when pushed hard. Over 400hp:popcorn:
So having said that here is the first design...............
http://i1129.photobucket.com/albums/...6-22134738.jpg
http://i1129.photobucket.com/albums/...6-22134748.jpg
http://i1129.photobucket.com/albums/...6-22134842.jpg
http://i1129.photobucket.com/albums/...6-22134909.jpg
http://i1129.photobucket.com/albums/...6-22172330.jpg
mini_macky Jun 30, 2011 08:18 AM
So...the last pic would be what you'd see if you're on the driver's seat & can see through the firewall?
dannyhavok Jun 30, 2011 08:28 AM
I believe that the last pic shows the view you would see standing on the drivers side of the open bonnet. You can see the cowl vents on the right hand side of the photo.
Revolution Mini Works Jun 30, 2011 08:28 AM
the last picture was taken from the LHD side
the box sits in the normal location
we will be offering one up with a 2.5" hose version later for the new superchargers we have coming and also the 3" version
mini_macky Jun 30, 2011 08:49 AM
I think I scrolled down & typed too fast as the last pic that popped up before I replied was the pic of the filter :lol:
So with the box mounted, the huge filter is angled downward?
Revolution Mini Works Jun 30, 2011 09:49 AM
yes, it allows a bigger filter for the space
there is also area after it to straighten out before going into the velocity stack
JumpingJackFlash Jun 30, 2011 11:15 AM
I don't imagine there is much restriction on a Stage I MINI S setup (15%, DDMWorks CAI, exhaust, tune). However, I'm sure that helps out your big MINI project a good bit. Nice design. :thumbsup:
gothmdoc Jun 30, 2011 12:12 PM
interesting... any hint of when you will begin marketing this?
Revolution Mini Works Jun 30, 2011 12:19 PM
right, we are not worried about the units with the stock chargers........as Mini was smart enough to make an airbox worthy.......however on our TVS900 kits that will be coming out, you will need a better flowing box all the way up to 3" design, hence the start of building something that will work:thumbsup:
it's only currently for the 1st gen Mini's
we may however make something for the R56s
Revolution Mini Works Jun 30, 2011 12:52 PM
Now to make sure the heat is reflected away from the box to keep it as cool as possible:thumbsup:
http://i1129.photobucket.com/albums/...6-30124917.jpg
http://i1129.photobucket.com/albums/...6-30124905.jpg
JumpingJackFlash Jun 30, 2011 01:12 PM
Yes, the heat reflective material should definitely help out. Man, you've been watching NASA TV alot lately. :wink:
minimarks Jun 30, 2011 02:02 PM
Good stuff!!!:thumbsup:
LüDICRöüS Jun 30, 2011 02:55 PM
http://images.cheezburger.com/comple...9017667908.jpg
tlr1000 Jun 30, 2011 04:03 PM
It looks too small...needs to be bigger :wink:
Seriously, that thing looks massive. Nice work.
Revolution Mini Works Jun 30, 2011 04:08 PM
actually it's not that big except the fact it's 3" outlet. We had one on the dyno running 1100hp Drag honda with the same design and the filter was about 2" longer and 1 in wider
tlr1000 Jun 30, 2011 04:46 PM
Does that panel air filter have more surface area than typical cone ones used on most R53 CAIs?
OldGameFreaK Jun 30, 2011 06:37 PM
Will a strut bar still fit with it?
Revolution Mini Works Jun 30, 2011 07:14 PM
http://i1129.photobucket.com/albums/...6-30191147.jpg
ClintTheMiniOwner Jun 30, 2011 10:04 PM
Like! how much? loud?
DICKS GARAGE R53 Jun 30, 2011 11:02 PM
I actually had about the same idea cross my mind, when I wasn't sitting behind a desk in Iraq, I decided against building the thing though, because even with a 3 inch opening at the intake, my throttlebody is only 63mm, and with the length and smoothness of the intake tube, you could have a 5 inch pipe and not gain a single HP IMHO. :lol:
ggcadc Jun 30, 2011 11:31 PM
sure DG, thats the problem if your using the stock TB and everything after... but i think that problem may have been thought through already
I like the looks, wish I had the need for it...
davisflyer Jul 1, 2011 05:11 AM
:confused::confused::confused:
Revolution Mini Works Jul 1, 2011 06:10 AM
thanks Davis..........at least someone can read and follow along........lol
I think I will hear rumbling in the back ground today............I hope to be at VIR on July 22nd...... you plan on stopping by?
jhiggs26 Jul 1, 2011 07:14 AM
Very nice Jan. Will there be an input for stock front air feed for stocker intake boxes?
Good news about the TVS900!
Jeremy
Revolution Mini Works Jul 1, 2011 07:26 AM
Jeremy
yes but this was designed for my car for testing
with all the piping in my car there wasn't any room:lol:
