R50/53 5 hour drive? No PS fluid? Thanks PartsGeek =/
Old Jun 17, 2011 | 10:02 PM
niquemarshall's Avatar
niquemarshall
Earlier this week, i ordered a liter of pentosin chf 11s for my MCS. I also paid an extra $20 for 2nd Day Air so i would get the part by Friday, so i can drive it back home. Ok so Friday rolls around, and the stuff still hasn't showed up, nor have i even been charged for the purchase although it has been "confirmed". Now im down to one option, which is to drive the car 5 hours back home with my reservoir empty.. Are there any last minute options i can try? Please respond if u can
Old Jun 17, 2011 | 10:35 PM
maxmini's Avatar
maxmini
I take it there are no BMW dealers near by as I would grab some before i left if i were you . I did a little on line search and found that VW uses something very compatible and perhaps Audi. Check this thread there appears to be some alternatives .
Randy
M7 Tuning
http://www.bobistheoilguy.com/forums...Number=1265165
Old Jun 18, 2011 | 04:02 AM
niquemarshall
Randy
M7 Tuning
Checked it out, and there seem to be alternatives... Hopefully i can find this stuff at walmart. Thanks for the help
Old Jun 18, 2011 | 05:31 PM
FiremanMike's Avatar
FiremanMike
Hope you get the fluid, there are no options I know of. The bigger question I must ask...why do you have a dry reservoir? It does not just 'go away', so are there drips/puddles under the engine?
My 02 S had a dry reservoir, I found all of the fluid in the outer boots, not one drip. The seals had blown and I replaced the steering rack.
good luck
Mike
Old Jun 18, 2011 | 08:05 PM
nopistons's Avatar
nopistons
Napa sells it
Old Jun 18, 2011 | 08:15 PM
MP1.6T's Avatar
MP1.6T
Confirmed 11S is the current Audi fluid
11S is the synthetic. Used in Audi's for 15+ years now. Sometimes found at dedicated import car part stores too.
To the OP, from having burned like this before, when I have to have it by date x, I always call to order and confirm everything live. Makes a difference sometimes; had that experience w/ ECS for example.
Old Jun 18, 2011 | 09:41 PM
Filmy's Avatar
Filmy
I have to do my online duty and report that I have had that experience with ECS Tuning myself very recently. With apologies for a temporary thread hijack...
They showed my three desired parts "in stock" on their website while I was ordering and finalizing. After not hearing anything from them for well over a week they told me the parts were "inbound" - meaning still on order from Mini. They even tried to BS me with a phony screen grab from my original order showing that the parts had to be ordered from the dealer. Like I said, a straight-up lie. I'll never order from ECS again.
Old Jun 19, 2011 | 08:28 AM
speeddriven85's Avatar
speeddriven85
Im sure you already figured something out, but Like nopistons said, NAPA always has CHF 11S so your best bet is to find your local store and pick up a bottle!
Also you probably have leaky PS lines. One end clamps to your PS pump (intake line) and the other is your return that goes into the drivers side of the rack. I recommend getting the leak taken care of. If that pump starves for fluid and you burn it up, you'll wish you spent the money on a couple of lines.
Good Luck!
Old Jun 21, 2011 | 11:31 AM
niquemarshall
Yea i called NAPA here and sure enough, they didnt have it.. i ended up using Lucas Power Steering Fluid thanks
Old Jun 21, 2011 | 07:34 PM
NH_MCS's Avatar
NH_MCS
You may want to have that Lucas PS fluid flushed out of your power steering system. The only fluid that's compatible with our MINIs is the Pentosin CHF 11s. You cannot run regular power steering fluid without negative effects on the PS pump since the pump was designed to operate with the CHF 11s which is hydraulic fluid. The different viscosity of the Lucas or any other PS fluid will make the pump work harder which in turn will shorten it's lifespan. Mixing the fluids is also another big no-no.
Old Jun 21, 2011 | 07:47 PM
niquemarshall
Yea i undersstand, but that was my only option since i had to go somewhere and i had no other PS fluid! No one carries CHF and i ordered some and it never came... Plus the lucas is watery just like the CHF and i havent noticed anything different thus far
rob&JCW
Feb 13, 2023 07:03 PM
Cereall
Sep 5, 2019 06:05 PM
Aug 19, 2015 12:51 PM
minipopkart
Aug 13, 2015 05:22 AM
