horn fuse keeps blowing!!
Old Jun 16, 2011 | 02:36 PM
Jahnnie's Avatar
Jahnnie
My horn fuse just recently started to blow immediately every time i honk my horn. Could there be a short somewhere? not sure if its gonna be a PITA to do myself to figure whats wrong or should i just bring it to the dealer/shop? Thanks!
Old Jun 17, 2011 | 01:12 PM
Capt_bj's Avatar
Capt_bj
there are two horns
I'd unplug one at a time and see if you can localize to one side ... and go from there.
Unfortunately the horns are a wee bit hard to get to ... Haynes recommends taking off the bumper cover. That's not hard but a bit intimidating the first time you do it.
If local to one side I'd probably swap horns and see if the problem goes with the horn. If yes you know what to do .. new horn. If the problem stays, well check the wires you can see on that side for a short, or just run 1 horn in the future . . .
Could be in wiring you can't see, or in the switch . . .
Old Jun 17, 2011 | 02:35 PM
Jahnnie's Avatar
Jahnnie
UPDATE
so i got a new fuse and started disconnecting each horn. first i disconnected the passenger horn. honked a couple times (nothing too long) and fuse is still good. plugged it back in and disconnected my drivers side and no horn is present at all but fuse is still in tact and relay is clicking. plugged the other one back in also and i can hear the horn again
soooo is it safe to say my passenger side horn is dead? i continued to honk several more times with both horns plugged in to see if the fuse would blow again but no blown fuse yet. could a dead horn cause my fuse to blow and is only a matter time before this new fuse goes out?
PsychoRallye
21
Feb 17, 2019 06:08 AM
mni928
Nov 9, 2015 07:38 PM
martinb
Oct 7, 2015 05:00 PM
Chefben63075
Oct 1, 2015 12:04 PM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
