Power Window Problems
Hey All,
The driver's side power window in my R53 no longer functions, not even when the door opens and closes. I have the bentley manual on the way.
I'm trying to figure out whether I should purchase a new motor with a regulator or without a regulator. When I press the switch down for the PW I hear a single click of unknown origin. This helped me eliminate possible fuse problems. The pax side window functions normally. I plan on replacing this myself.
Could someone possibly help me discern whether or not I should purchase the motor with or without the regulator, because there is a price difference.
Thanks!
Jon
Thanks!
Jon
I can't really help you too much, but in the short term....
My pass window does not function occasionally when the weather turns hot. A temporary fix is to hold down the window switch while giving the door a nice bang with your fist, just above the speaker towards the front of the door. For some reason this works for a while.
- drew
- drew
thank you all for the comments, I had problems with the passenger power window of my mini 2004, I found the way to take the door panel to see if I could solve it, when finally I found this blog, I bang the door with the switch on and it worked, I banged right on the motor, like 4 to 6 inches from the tweeter, I know the motor will eventually die, but not yet, thanks again.
Window regulator binds
@WayMotorWorks
I have installed a new regulator in the door. Now the system seems to bind (for lack of a better way to describe it). If I lower the window all the way down and let it sit, when I try to raise it I can see the cables on the regulator flex when the motor tries to actuate the regulator. I have removed the entire regulator and inspected it for any defects. I reconnect the regulator and the system works.
This has occurred twice and I am tired off fighting with those nuts on the window. Do you have any suggestions?
First you need to align the glass. 83300494251 , Then reset the window points
https://www.northamericanmotoring.co...regulator.html
https://www.northamericanmotoring.co...pped-help.html
Dec 23, 2015 10:36 AM
