Lock on one door not responding to fob
Old Jun 7, 2011 | 04:09 PM
Thomas.Wright's Avatar
Thomas.Wright
Just curious if anyone can tell me where to look to fix this?
The driver's door MUST be locked and unlocked manually with the key. Everything else works just fine with the fob.
Any thoughts? easy/hard fix?
Old Jun 7, 2011 | 06:01 PM
JumpingJackFlash's Avatar
JumpingJackFlash
Do you mean the lock is messed up, or do you mean the keyfob unlock button is not working correctly?
Old Jun 7, 2011 | 08:23 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
More than likely you'll need a door lock actuator
http://www.waymotorworks.com/oem-door-actuator.html
Old Jun 8, 2011 | 06:58 AM
Thomas.Wright
To clarify, the fob works fine on everything except the driver's door. I must use the actual key in the lock on the driver's door. Both lock and unlock.
Old Jun 15, 2011 | 12:54 PM
Thomas.Wright
Is the actuator an electronic item or a mechanical one?
Old Jun 15, 2011 | 01:16 PM
cristo's Avatar
cristo
Alliance Member
Both. It's the latch mechanism, and it has a couple solenoids in it and
connects to a wiring connector, as well as a couple levers and cables attached.
Old Jun 15, 2011 | 05:33 PM
WayMotorWorks
Vendor
The actuator is the complete electronic part and latch in one assembly
Paul!
Electrical
16
Feb 18, 2025 06:29 AM
Filmy
Sep 7, 2015 08:27 PM
Sep 3, 2015 10:45 AM
Ntety
Sep 2, 2015 08:39 PM
spackletooms
Sep 1, 2015 10:12 PM
