R55 Where does this piece go?
Old May 31, 2011 | 05:24 PM
roomtone's Avatar
roomtone
After a car wash while drying up the back of my 2009 Clubman I opened the barn doors and ran a towel along the inside of the doors. When I went to close the left door I noticed it wouldn't close and there was a rubber stopper sitting there. I picked it up and then the door would close.
The problem is that I have no idea where it goes.
The part number is mini 51492756547.
I found a layout of the Clubman rear on this webpage (Part #15): http://parts.miniofsouthatlanta.com/...ey_trimLevel=0
After looking at it I'm still at a loss. I think I need to see a picture or another Clubman backside so I know where it goes.
I have also attached a picture of the actual rubber bumper.
I appreciate your assistance.
Greg
Old May 31, 2011 | 06:01 PM
LadyGodiva's Avatar
LadyGodiva
This diagram might be a bit better.
It sits above the bumper, centered and tucked under the rubber seal. Hope that helps!
Old May 31, 2011 | 06:04 PM
PantherJCW's Avatar
PantherJCW
rubber stoppper
I have knocked mine off a couple of times with a towel also. It wedges right in the middle of the doors jst above the bumber cover. There is a large round bolt there that you have to wiggle it around to get it seated properly.
Old Jun 3, 2011 | 08:40 AM
rlw's Avatar
rlw
Yep, I've dislodged mine a few times when cleaning the car. If you remove the bolt and slide the piece in place it will go right back as it should...
Old Nov 18, 2011 | 03:58 PM
roomtone's Avatar
roomtone
The piece is back where it is meant to be.
I appreciate everyone's help with this.
Thank You,
Greg
Old Nov 19, 2011 | 07:52 PM
Yakatak's Avatar
Yakatak
Ha. That piece has been sitting on my workbench for weeks now, in hopes I would discover where it came from. Thanks guys!
Old Dec 14, 2011 | 08:09 AM
jrwmini's Avatar
jrwmini
Diagrams
LadyGodiva,
Where did you find this diagram? I have been looking around for a site that has them, but have been unsuccessful. Just want to make sure I have all components necessary for some DIY jobs.
Thanks!
Old Dec 15, 2011 | 05:09 AM
schatzy62's Avatar
schatzy62
You can go to the following to find these.
http://www.realoem.com/bmw/select.do
http://www.penskeparts.com/index.aspx
You will need go thru the selection process to get to the correct diagrams for your car. but that is relatively easy.
OutMotoring
Mar 3, 2017 06:29 AM
luisfv56
Nov 16, 2015 01:55 PM
ToroPerro
Oct 1, 2015 12:54 PM
Adam Bradbury
Sep 28, 2015 04:15 PM
BMC_Kid
Sep 27, 2015 04:31 PM
