Rotor Bolt
Old May 29, 2011 | 03:45 PM
Wetworth's Avatar
Wetworth
Rotor Bolt
So the mechanic I took my car to years ago stripped the bolt that hold the rotor on the front right. The only way I can see to get it off is to drill it out. My question: can I drive without that bolt or will the cause problems?
Old May 29, 2011 | 04:04 PM
daflake's Avatar
daflake
You don't need the bolt. It only aligns the rotor when mounting the tire. I have been driving without one for several years now.
Old May 29, 2011 | 04:27 PM
Wetworth's Avatar
Wetworth
Good to know, thanks!
Old May 29, 2011 | 04:52 PM
AXO's Avatar
AXO
The bolt is only a couple of bucks for a new one
Old May 29, 2011 | 05:38 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Yeah Wil, it's only a few bucks ! You cheapskate !
Old May 29, 2011 | 05:46 PM
daflake's Avatar
daflake
And lazy...
Old May 29, 2011 | 06:27 PM
Vollgas's Avatar
Vollgas
The bolt can be drilled out and removed using an Easy Out tool.
When you replace the bolt, put a little antisieze on the threads.
It will make it easier for the next tech that has to work on it.
Old May 29, 2011 | 08:55 PM
HRM's Avatar
HRM
I buy things like that since they are cheap and if ever you are right there, feel like messing with it, you have the $2 part if you can get the old one out. If not, sooner or later when you buy new rotors, you will have one.
Old May 30, 2011 | 10:00 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Try turning it out with a hammer and chisel first, that will be easier than drilling it out.
If you need the bolts we stock them too.
Old Dec 10, 2011 | 12:26 PM
scf's Avatar
scf
What's the thread size for a thread chaser? I snapped the head on one today. Drilled it out down to the threads, and put the new bolt in my cup holder.
Old Dec 11, 2011 | 12:49 AM
Eric_Rowland's Avatar
Eric_Rowland
If you have the new bolt, can't you just figure the size with a die (assuming you have a set)?
Old Dec 12, 2011 | 04:34 AM
scf's Avatar
scf
here in lying the problem. I'm going to take it with me down to Lowes, and use their thread gauge.
ericbryant24
55
Sep 30, 2024 02:10 PM
David.R53
Sep 13, 2015 03:44 PM
marc0011
Sep 10, 2015 10:04 PM
Sep 10, 2015 10:52 AM
Sep 4, 2015 09:23 AM
