R56 CV Boot Grease Question
Hey Guys,
I am about to replace both my inner and outer cv boots on the passenger side of my 2007 mini s. I got the kit from the dealership and I know that the inner and outer use different grease. My question is which grease is the inner and which grease is the outer? I have a 130ge and an 80ge. Does anyone know which is for the inner and which is for the outer?
From Audi experience...
if that helps: the bigger grease capacity typically goes on the outer joint. If the boot is bigger on the outside (always has been on cars I have done), another simple way to confirm. Inner joint only has to handle in and out axle movement with suspension and a limited deflection angle, while outer one has to handle full lock to lock steering angles. Thus, bigger joint area = more grease.
I expect the grease is functionally the same, just varying quantities. I have seen it packaged differently from boot to boot kit, but found it all fundamentallly the same stuff.
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
LordOfTheFlies
Oct 19, 2015 05:02 PM
brother i
Aug 23, 2015 01:15 PM
Kahnfucious
Aug 15, 2015 08:43 PM
