Strange whistle when AC is running
Old May 23, 2011 | 03:29 AM
SilverSVS's Avatar
SilverSVS
Greetings,
I was wondering if anyone else has experienced getting an intermittent whistling noise when the AC is running. The whistle gets louder and more frequent when the fan speed is increased. Could it be the AC motor? Would the whole thing have to be replaced, or could I just spray some WD-40 onto it?
Thanks for your help.
M
Old May 23, 2011 | 04:00 AM
s2k7's Avatar
s2k7
Originally Posted by SilverSVS
Greetings,
M
Listen carefully, where is the sound coming?
If you hear inside, check your vent if there is obstruction. If its in the engine bay, could be a worn belt or needed an adjustment. Do not spray the belt with WD-40 instead buy a belt dressing. Spray belt, see if quites down.
Low freon level will also cause a hissing/whistling sound hearing from the vent area.
Old May 23, 2011 | 01:46 PM
SilverSVS's Avatar
SilverSVS
Thanks, I'll check it out.
Old May 23, 2011 | 02:44 PM
mini53's Avatar
mini53
The mice that spin the cage fans get old and start to weeze when pressed harder.
Old Jun 17, 2011 | 11:38 PM
SilverSVS's Avatar
SilverSVS
Problem fixed
I ended up replacing the AC Blower motor. All whistling and chirping sounds have stopped. The part cost me about $90, diagnostics and labor ran me about $150.
coachvminis
Aug 25, 2015 06:58 AM
Ryephile
Aug 25, 2015 06:51 AM
AdrenaliNate
Aug 24, 2015 12:37 PM
makg
Aug 21, 2015 02:49 AM
Getrieben
Aug 15, 2015 09:09 PM
