Suspension JCW Spring Struts Id
Old May 19, 2011 | 05:21 PM
xman11's Avatar
xman11
I'm considering picking up a used set of JCW springs/strut package from a 2003 JCW. Are there any distinguishing marks that show that it is genuine JCW springs/strut, e.g. are the springs red and not black? I read that the struts are made by Delphi.
Also, did the JCW suspension change from 2003 to 2006?
Thanks in advance!
Last edited by xman11; May 19, 2011 at 09:57 PM. Reason: Discovered JCW kit will fit with retrofit.
Old May 19, 2011 | 10:08 PM
ggcadc's Avatar
ggcadc
look here for the part numbers, that will likely be the only way to differentiate.
http://realoem.com/bmw/showparts.do?...17&hg=31&fg=10
Old May 20, 2011 | 04:21 AM
NH_MCS's Avatar
NH_MCS
I believe both applications use Delphi shocks. The JCW springs should be red and the shocks will have a JCW marking on the white sticker on the shock body. This is only the case if the car has the dealer installed "JCW suspension package". However all JCW cars did not come with the "JCW" suspension, most of them had the same sport suspension as the non-JCW Cooper S.
Old Aug 22, 2011 | 08:32 AM
Wallywrld's Avatar
Wallywrld
jcw struts
Is this a good choice for lowering and does it get it low enough. Does anybody have pictures of there JCW mini with this suspension. thanks
Old Aug 23, 2011 | 05:16 PM
meb58's Avatar
meb58
10mm drop and that's all you need..low enough if you are concerned with good handling dynamics. 13mm is a half inch.
This is decent kit but I don't think the shocks are strong enough to control the springs. So I would opt for Koni yellows and amte those tp the JCW springs. This is a very effective combination.
Old Jun 8, 2012 | 07:00 AM
davisflyer's Avatar
davisflyer
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
jeremy_reyes94
Sep 6, 2019 07:53 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
nomar116
Aug 10, 2015 11:24 PM
