R56 How do you get the battery out?
Old May 14, 2011 | 09:31 PM
Btwyx's Avatar
Btwyx
Tristan's battery died this afternoon, after sitting with the engine off and the fan on for about an hour, so I'm thinking it might need to be replaced. I've replaced batteries on other cars before and never had a problem, but I can't see how to get the battery out. Its buried under a plastic bulkhead, and the hole to access the battery isn't big enough to fit the battery. So what's the secret?
Old May 15, 2011 | 12:44 AM
Tio Barry's Avatar
Tio Barry
Never done it but the plastic bulkhead comes off.
Old May 15, 2011 | 01:24 AM
MiniBOL's Avatar
MiniBOL
Just find the screws that holds it. There's about 3 or 4 I think. Just remember how the panel is sitting when you take it out cause it was a b!tch putting back on.
Old May 15, 2011 | 04:41 AM
miniSQ's Avatar
miniSQ
i took my battery out and cracked the plastic housing. There are 3 bolts that need to be removed, and then the trick is to slide the housing up and out. If you search the forum you will see instructions.
Putting it back is just as tricky...it needs to slide back into position exactly, as the cowling acts as a water shield against the windshield.
Old May 15, 2011 | 12:33 PM
kmethchu's Avatar
kmethchu
I just changed my battery and found that it's a bit easier to get the panel out if you take off the passenger side windshield wiper first.
wildwestrider
11
Jan 29, 2016 05:06 PM
SJ-R50
Oct 28, 2015 08:39 AM
schr5530
Oct 5, 2015 08:28 AM
MiniSMan
Sep 29, 2015 06:38 PM
jennster
Sep 28, 2015 06:19 PM
