R56 Sunroof Question
Sunroof Question
Hello! Brand New Owner and Brand New Member!
I have a question about the sunroof...Ive seen various posts about the sunroof not working and getting stuck open. There is a tool to close it manually...the question is, where is this tool and how do i close it manually if I get this problem. I have a 2008 MCS. I already looked in the tray under the rear boot and dont see a tool Id use to close the sunroof nor do I see where it would fit.
Thanks!
Thanks!
i have heard about this tool as well but am not aware of where it would be located. The main issue ive heard of with the sunroofs is that they have trouble working in hot conditions. I hope mine never gets stuck open.
Thanks!
Thanks!
Looked at my '10 Clubman. I popped off the plastic cover as shown in the older owners manuals. (Cover has airbag light and color LED's).
There is a ~ 0.75" hole in the black plastic part. Above the hole is the drive motor. In the center of the motor there is a hole that fits #20 torx driver. (The larger of the torx on the included screwdriver tool). You have to pull the driver handle part way off in order to have enough reach.
I inserted the torx driver and ran the sunroof with switch and the driver turned with the motor. I did not try to turn manually because I did not want to break something, but I would try it if my sunroof ever gets stuck open.
I am not sure you could turn it with the included screwdriver torx tool. Might have to use a large allen type or 'T' handle torx tool or maybe even a drill motor driver.
Thanks!
Thanks!
Colt45Magnus
Aug 27, 2024 05:03 AM
Manny_cooper
Sep 3, 2015 05:48 AM
Interior/Exterior Another hood stripe removal thread
broncobuddha
Sep 1, 2015 06:32 PM
