Suspension 15"wheels on an R56
Old May 12, 2011 | 05:31 PM
DUCTTAPE's Avatar
DUCTTAPE
15"wheels on an R56
Hi
Is anyone running 15" x5.5 4-100 on a 2011 R56S? I am outfitting for next winters ALCAN 5000 MINI run and need six snows. I don't want to run the stock rims because I don't think I can find two more and I also don't want to switch tires each season, just wheels.
Anyone?
Old May 12, 2011 | 07:16 PM
AXO's Avatar
AXO
I dont think they will clear your brake calibers.
Old May 13, 2011 | 05:08 AM
DUCTTAPE's Avatar
DUCTTAPE
Bummer...
Old Jun 10, 2011 | 11:45 PM
irishpunk's Avatar
irishpunk
Check out Konig Feathers (15") and the 949racing.com 15" 6UL wheels - according to what I have read here they both should fit.
Old Jun 10, 2011 | 11:46 PM
irishpunk's Avatar
irishpunk
Just refocussed on the 5.5 - I think both Konigs and 6ULs are 6+ - sorry - did not get that part
Old Jun 11, 2011 | 07:57 AM
bluefox280's Avatar
bluefox280
Correct, 16" wheels are the minimum on the S-model R56's.
15" wheel only just the base (non-S version) Coopers / Clubmans.
- Erik
Old Jun 12, 2011 | 06:36 PM
DOC4444's Avatar
DOC4444
I have a 2010 Justa and fitted snows on 15" Honda Civic steel wheels. They clear the calipers by less than 1/8". No chance fitting 15s to an "S".
DOC
Old Jun 13, 2011 | 06:25 AM
JamesL_71's Avatar
JamesL_71
The R56 Cooper S has 11.6" rotors... while large for OEM brakes, they will indeed fit with some 15" wheels.
The wheels that clear these brakes will usually be geared towards performance driving/racing, as brake clearance can be a very important variable to be considered when designing and manufacturing wheels.
There is a thread somewhere on this forum with a list of 15" wheels that will clear the stock R56 and R53 JCW brakes. Suffice it to say that there are ~20+ different wheels that are known to clear the 11.6" brakes.
A few examples:
*949Racing 6UL -15x8, 15x9 (the 7s and 7.5s have less brake clearance).
*Enkei PF01 - 15x7, 15x8
*Team Dynamics Pro Race 1 and 1.2 - 15x7
*SSR Comp/Type-C - 15x7, 15x7.5
*Volk TE37, CE28 - 15x7, 15x7.5
As you can see.... there is a bit of a trend here. Most wheels on this list are forged or low pressure cast, resulting in the ability to produce a wheel that has less wall thickness on the inner portion of the rim, and thus more brake clearance.
Blah blah blah... The point is, only some 15" wheels will clear the front brakes on an R56.
I am not aware of any 15x5.5" wheels that would work, though. And the OEM base Cooper wheels will definitely not clear.... and neither will any of the standard steel wheels that are stock on so many smaller cars.
Old Jun 13, 2011 | 07:07 AM
DUCTTAPE's Avatar
DUCTTAPE
So the steelies for snows are out then, eh? That was quite a listing. Thx for all the news everyone.
Old Feb 19, 2016 | 12:40 AM
E30M3's Avatar
E30M3
- Erik
Incorrect sir.
Old Sep 5, 2017 | 12:42 PM
Minibeagle's Avatar
Minibeagle
Originally Posted by E30M3
Incorrect sir.
Attachment 144346
Looking to get into a 15x8 setup on my 2006 JCW, mostly used for auto-x and some lapping. This post and thread are very helpful.
Old Sep 5, 2017 | 12:52 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
949racing 6ul fit, pay attention to where wheel weights are mounted
Old Jan 16, 2018 | 12:19 PM
Minibeagle's Avatar
Minibeagle
Anybody know if Konig Dial-In in 15x8 would fit over R56 front calipers?
Old Jan 27, 2020 | 05:51 AM
Minibeagle's Avatar
Minibeagle
Reviving and old thread
Has anyone come across other 15x8 or 15x9 wheel models that clear front R56 / R53 JCW front brake calipers?
Old Jan 27, 2020 | 08:40 AM
MrBlah's Avatar
MrBlah
yeah the 949racing 6ul fit over them, I mentioned that just a couple posts back
Old Feb 22, 2020 | 02:25 PM
r53racer's Avatar
r53racer
I know its mentioned that te37 fit, would rota grids 15x7 fit?
Old May 7, 2024 | 02:03 PM
SammyR56S's Avatar
SammyR56S
Calibre Motion 15"
Hi, jumping on an old thread but keep getting so many mixed responses.
I have purchased calibre motion 15" alloys, they were supplies by rimstyle and have been reassured they will fit my 2007 cooper s but was hoping somebody here could confirm that?
Thank you 😊
Old May 8, 2024 | 06:21 AM
Yoshimura 1's Avatar
Yoshimura 1
Why would you even put 15 inch wheels on a R56 S when they come with 16-----17 inch wheels......
Old May 8, 2024 | 06:22 AM
SammyR56S's Avatar
SammyR56S
helpful 🙄
Old Sep 9, 2024 | 05:18 AM
PAdutch's Avatar
PAdutch
I got a single wheel in this weekend to test fit on my R57s
Cosmis Wheels MRII Gloss Black 15x8 +30
https://cosmisusa.com/products/mrii-...RoCZxoQAvD_BwE
Seems to have plenty of brake clearance front and back. Front strut was about .25" id say. Looked like very good fitment. I going to order the full set, pics to follow.
Old May 28, 2026 | 11:42 AM
cbseven's Avatar
cbseven
Anyone know if the 15" Kosei K1's will fit the R55 S?
thebordella
Aug 31, 2015 01:37 PM
trw92a
Aug 26, 2015 01:47 PM
Zettinger
Aug 25, 2015 04:04 PM
