Stuck bolt help
Old May 11, 2011 | 11:26 AM
msswett's Avatar
msswett
Stuck bolt help
Replacing my LDP to clear a fault code. Trying to remove the old one, but one of the two bolts holding the canister won't come loose. The nut is supposed to be held in place by a plastic bracket. But, for some reason, the nut isn't being held firmly and is turning along with the bolt.
Anyone familiar with this assembly have any suggestions?
Old May 11, 2011 | 01:16 PM
HRM's Avatar
HRM
I had a similar issue with the radiator or AC condensor. It was an optional thing, but I just left it since I wasn't in the mood. I decided next time I would use epoxy on the plastic nut (Create a wedge between the side and the basic nut shape of the thing. After hardening, this should prevent spinning.
Maybe something like that works for you too?
Old May 11, 2011 | 06:28 PM
msswett's Avatar
msswett
Thanks for the reply. There is so little room between the canister and the gas tank I don't think I can get anything in there at all, let alone accurately enough to accomplish anything.
It looks like I'm stuck until I get a new canister housing. Then I'll cut it out and replace the whole LDP/canister assembly.
Cruzer214
Oct 11, 2015 07:45 AM
Fordgt4
Oct 10, 2015 10:42 AM
MINI Stupor
Oct 1, 2015 11:36 AM
micromini234
Sep 30, 2015 07:36 PM
Nicefeet
Sep 24, 2015 06:53 PM
