N18 – Cold Start Exhaust Rattle Noise (Turbo Wastegate)
Old May 9, 2011 | 03:13 PM
Navlancer's Avatar
Navlancer
My '11 S Clubman has <1K Miles. Owned it all of 11 days. I started the car this weekend with the door open, and heard a rattling noise. Lasted 30sec-1min thereabouts, than was gone. I thought, "uh-oh death rattle, but already?"
Checked for it again this morning, and sure enough, 30-60sec, then gone.
I called local dealership, the SA said, this is normal , his S does same thing, it's the turbo wastegate making the noise.
Of course, I didn't believe him, searched some more in forums and on the net, found the attached SI.
1) Has anyone else noticed this issue?
2) If you have, is there a fix other than that I have heard, and then read? ("Live with it")
Is it me, or should a brand new car not make a noise on startup?
Cheers,
Navlancer
File Type: pdf
Old May 9, 2011 | 08:08 PM
cub4bearindiana's Avatar
cub4bearindiana
Cheers,
Navlancer
nothing new.. same here.. I AM LIVING WITH IT !!!
after all it is about the driving fun.. not how my car sounds after start
Ok guys, here is how my sounds this morning after all night in garage.
Old May 10, 2011 | 10:17 AM
pheatton's Avatar
pheatton
Yep same noise here. While I was at the dealer they had a 2009 with the death rattle. Its not the same noise. It sounded more like a slight knock then a rattle. You could hear something smacking and rattling around inside.
Old May 10, 2011 | 01:24 PM
johnf36's Avatar
johnf36
You may have tensioner problem
Old May 10, 2011 | 01:33 PM
Gil-galad's Avatar
Gil-galad
Not likely. See the previous post. It's a much different noise and it's source is on the opposite side of the engine.
Old May 10, 2011 | 01:44 PM
johnf36's Avatar
johnf36
your right I got my threads mixed up
Old May 10, 2011 | 06:05 PM
Roundel's Avatar
Roundel
My '11 has this too, and I'm relieved it's not a tensioner. If it's a wastegate there really is no ill effect.
Old May 10, 2011 | 06:15 PM
jomama's Avatar
jomama
my car sounds just like cub4bear's car in the video. i haven't thought anything of it, esp since it pretty much goes away by the time i pull out of the carport.
Old May 10, 2011 | 06:26 PM
Professor's Avatar
Professor
This a new item on the N18. The waste gate stays open at idle to help heat up the cat faster. The waste gate cup is what you hear rattling.
What the SA at the dealer said is correct. Mini/BMW even thought enough of this item to discus it during qualification on this engine.
Old May 10, 2011 | 07:25 PM
yanks4285's Avatar
yanks4285
Yep 2011 MCS here. I'm living with it, cars under warranty. If it breaks it breaks. No real concern.
Old Feb 21, 2013 | 10:41 AM
bmx045's Avatar
bmx045
sorry for the bump, my 2011 does the same, I almost **** myself because I thought it was a tensioner issue, at 14k miles! glad to hear it's something else.... (and yes, oil level is fine).
Old Feb 22, 2013 | 10:22 PM
boOst spIKe's Avatar
boOst spIKe
QFT.
Old May 31, 2018 | 10:56 AM
MrGrumpy's Avatar
MrGrumpy
I think this really is pretty common, mine makes that noise on startup too, but then again, my waste gate is hanging open, and needs fixed.
there is a warranty extension on it, 10 yrs 120K, mine is at Mini right now for it.
apparently, it is a well known issue stemming from the proximity to the exhaust manifold, with the heat causing the waste gate to fail.
It might be worth getting it looked at
Old Nov 19, 2024 | 08:20 AM
TpaMiniac's Avatar
TpaMiniac
Reviving this old thread! My '11 R55 sounds like this as well and has my concerns up a bit. I replaced the tensioner on Saturday and same sounds. It has 47k on it. Would this be the wastegate noise or should I be doing a timing chain service?
iggi
18
Feb 9, 2026 01:00 AM
Getrieben
Sep 12, 2024 07:03 AM
TREX
Nov 2, 2019 07:31 PM
elightbo
Aug 17, 2015 01:50 PM
