R56 R56 Key Questions
R56 Key Questions
I just wanted to get a few questions answered regarding my keys from some experts, or people that may have been in the same situations. BTW I have a 07 R56. I did a search but found nothing, so I'm sorry if the questions have already been answered.
1. When I'm driving, my key sometimes falls right out of the ignition. Kind of scary when it happens while I'm on the freeway. Prior to this, I noticed that the chrome bezel is cracked and missing a portion of it on the key, so I just took it off. Is the missing chrome bezel somehow a making my key fall out, or is it the ignition slot? What actually holds the key in place? Magnet?
2. I am also missing my 2nd key. From what I understand, you can't just buy a second hand key from eBay and program it yourself like earlier MINI models. I am being told that there is no way around it... you have to go to the MINI dealer and order a key from them, and have them program it. Is this correct?
1. I don't have the chrome ring on one of my keys. I tried pulling it off to paint it and I broke it.
It hasn't just fallen out of the ignition though. That's weird.
2. Correct. You have to get a new key from the dealer. In most cases, I've heard it costs between $300-$400, but I could be wrong.
It hasn't just fallen out of the ignition though. That's weird.2. Correct. You have to get a new key from the dealer. In most cases, I've heard it costs between $300-$400, but I could be wrong.
Likewise lost my chrome bezel for a while...
and didn't affect key in slot security. Can buy that ring as a separate piece part by the way.
As others say, need a trip to get it programmed. You can order the key via a discounting/on line dealer first if you want; the key is ordered by VIN number, so on arrival it is cut correctly, but still needs the programming.
Thank you very much to all the members that made a quick replies to my questions.
I figured that the chrome ring had no real function, but I just wanted to be sure. I'll be visiting the stealership this week to find out the exact cost of the replacement key, and chrome ring.
As for the key, it seems to be popping out when I hit a large dip in the road or bump in the freeway. I'll have the stealer look into that too.
I had the chrome ring break on both of my keys. The dealership fixed it with new rings and said that they are covered under warranty. Next time you are in, bring the key with you and hopefully they will fix it.
I was unaware that they had a stainless steel type, and I will definitely look into getting that version.
That's exactly how mine started... it would come out at first if I pulled slightly, then as time went by it got worse and started falling out on its own.
I took the car into the dealership, and they said it was the first time that they have ever heard of a key falling out on its own. It was a quick fix. They had to replace the ignition module.
Also, to confirm what other members have already stated, that the chrome colored plastic ring is now a discontinued item. They only stock the much better stainless steel ring, which was covered under warranty.
skippermini
Aug 13, 2015 06:13 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
. If so the added weight may cause it to pop out. I have comfort access and rarely put the fob in the holder.
