R56 Why don't my doors autolock when I put the car in drive?
Old Apr 25, 2011 | 08:02 AM
MiamiGuitarMan's Avatar
MiamiGuitarMan
2011 Mini convertible. I've read on a few threads that the doors are supposed to lock automatically when you put the car in gear. My last car did this. Any idea why my mini isn't doing this? Is this a feature that only comes with certain packages or is something not set up right in mine?
Old Apr 25, 2011 | 08:13 AM
iamwiz82's Avatar
iamwiz82
It's a personalized setting Dependant on the key. Use the OBC button to cycle to Set/Info, the full writeup is in the manual.
Note: I have no idea about autos, but my manual locks on drive-away.
Old Apr 25, 2011 | 08:16 AM
MiamiGuitarMan
Thanks. I did look in the manual and followed the instructions in there. It still didn't work although I suppose I may have followed the instructions wrong.
Old Apr 25, 2011 | 08:51 AM
ammodave's Avatar
ammodave
The instructions in the manual are a little cryptic. Did you have car running when you attempted to reprogram the fob? My 2010 won't reprogram unless the car is actually idling; if I recall correctly, the manual makes it appear you can do this after simply pressing the start/stop button without actually starting the engine. Your car is a 2011; if all else fails, return to the dealer and let your salesman assist you.
Old Apr 25, 2011 | 08:54 AM
DneprDave's Avatar
DneprDave
My doors lock when the car reaches 10 miles/hr.
Dave
Old Apr 25, 2011 | 09:08 AM
iamwiz82's Avatar
iamwiz82
My 11 required the engine to be on as well.
Old Apr 25, 2011 | 09:42 AM
MiamiGuitarMan
Ok, got it figured out. Nothing like the controls in a new car to make you feel like an idiot. The instructions are definitely a little cryptic, at least to me, and what's shameful is that I work in IT and deal with technology and cryptic instructions on a daily basis so this makes me feel double stupid, but after some trial and error I got it working. The little symbols and icons they use in the settings are pretty much useless and not intuitive at all.
Old Apr 25, 2011 | 09:57 AM
jomama's Avatar
jomama
worse is the two settings for auto-lock are indecipherable. one looks like auto-lock and so does the other! when i realized that it still wasn't auto-locking, i toggled to the other setting and it did.
btw, anyone know whether or not you need to completely redo your settings if you were to pull your battery?
Old Apr 25, 2011 | 10:39 AM
MiamiGuitarMan
My understanding is that most of these settings are stored in the key so they won't disappear if you disconnect the battery.
Old Apr 25, 2011 | 10:44 AM
theunclesam's Avatar
theunclesam
As a side note to this: If you have the MINI connected system, you do all (except auto wipers) the OBC settings through the screen. It has text to go with the icons so it's much easier to figure out.
Old Apr 25, 2011 | 10:51 AM
jomama's Avatar
jomama
sweet! thanks for the info. not that i plan on doing any mods that require me to disconnect the battery any time soon, but this is good to know. losing all those settings/presets would kind of suck!
Old Apr 25, 2011 | 11:54 AM
MINIxB's Avatar
MINIxB
Most of the settings are including radio stations and temperature settings on the Auto A/C
Dec 23, 2015 10:36 AM
maestro39
Oct 27, 2015 02:38 PM
SoCalledFriend
Aug 6, 2015 06:59 AM
