Suspension H-sport lower camber link help
Old Jan 20, 2004 | 06:07 AM
MSFITOY's Avatar
MSFITOY
Got my Hot Dawg fired and am getting prepared to install my H-sport camber links. Has anyone done a how to? I'd appreciate a link. If not, would you guys share your experience with me...pitfalls, etc. Ryan, I'd especially appreciate a write up from you.
Thanks in advance.
Sid
Old Jan 20, 2004 | 06:27 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
They are easy Sid. Two bolts and the old ones come out. The bottom ones are easy to reach, but the top ones are a bit of a *****. Two people helping on the one side helps. Once you have one out, set the length of the new bar to the old bar to give your self a good starting point. Then bolt them in. look at what way the bolts go in and put them back in the same way. I put the pass. side bar in the other way form the directions on Ryan’s car by accident and we realized it was that way after the car was back on the ground, but it looks easier to adjust since it's not right next to the exhaust pipe. Take a look at yours and see if that will help you. Other than that…good luck.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Jan 20, 2004 | 06:57 AM
Ryephile's Avatar
Ryephile
as always - the right tools and lots of patience make the job quicker and easier
Old Jan 20, 2004 | 07:09 AM
MSFITOY's Avatar
MSFITOY
Hey thanks guys Did you have to do anything special with the shock/springs? Just jack up the rear, take off the wheels and get to work?
Sid
What kinda rummaging around are you referring to Ryan??
Old Jan 20, 2004 | 07:11 AM
MSFITOY's Avatar
MSFITOY
Chad, can you elaborate or further explain your comment. I'm not sure which part you're referring to.
Thanks,
Sid
Old May 14, 2010 | 08:43 PM
NicoF's Avatar
NicoF
what was the torque spec. used for the adjustable lower camber link?
Old May 16, 2010 | 06:41 PM
DaveVT02S's Avatar
DaveVT02S
Haynes says 74 ft/lbs (both ends)
Old May 17, 2010 | 06:13 AM
NicoF's Avatar
NicoF
thank you Dave
dropnstylez
Oct 29, 2015 08:57 AM
wesmc
R55 :: Clubman Talk (2008+)
Sep 28, 2015 12:07 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 11:15 AM
